Intake Manifold ID ?
I have a GM manifold I was told was from a 64, but there is a guy on here that has one for sale and mine has different numbers.
Rear G M 3795397
Thanks for your help.
Rear G M 3795397
Well isn't that just special!!!
When i put my 62 together back in 73 it looks like I took the wrong manifold off the shelf, I geuss I will have to remove the carb to see all of the numbers on that manifold.
The last 5 numbers are 32472 the float is covering the rest of them.
Received 1,857 Likes
The 62 intake will only take a Carter AFB carb and if you really have the Z-28 intake on (which sounds like you do seeing that there is a fuel bowl there) it only takes a Holley carb.
You better make sure you have a carb for the 62 intake before you do anything (or you'll have to get a carb adaptor for the Holley)
If you go with a carb adaptor you may not have enough hood clearance and oh yeah - you are going to need a different air cleaner than what you have on the Holley now (or you'll need an adaptor ring too LOL !)
Have fun !!
POSSE ZR-1 Driver
And if you are loooking to offload that Z28 manifold, PM me.
Solid, How did you manage to put the wrong intake on ?
Have fun !!
Have fun !!
With that in mind I guess I can not sell either one as I do not have a WCFB and the car runs great with the Holley, so I guess I am stuck with the Z-28 on the numbers matching car with the wrong manifold !
I do not want to alter the hood for the different carb so I guess you have answered this old problem
Thanks for all the help.
