are my valve covers original?
ZADSPAL,
Corvetteforum@522266 (02-10-2024)
Which horsepower do you have? The 327/300 used a painted, stamped, steel cover. The aluminum covers were only used on the 327/350 horse motor in 66. January build might be a little early for the seemed covers, if it's a 350HP car.
I think as the years went on and they continued to make parts on the worn out tooling the covers got more "ugly". The seam became more pronounced and the "o" in corvette started to fill in with flash in the center somewhat. Look at an original 66-7 part and a later repro and the difference is astounding.
jd
jd
If Lester pn 3767493 and they are "correct" for your engine config (L79 - yes) and they have the casting "flaw" appropriate for your car's build date (such began appearing on L79s beginning at some point in the 66 model year, someone with their NCRS TIM&JG handy will provide precise date) then you are as close as you can get to concluding they are "orignial" to your car. If not orginal to your car, someone went to the trouble (or got lucky) to source "correct" valve covers for your car at some point.
By the way and FWIW, when I acquired my 65 L76 in 2003 (original engine car), it had casting flaw valve covers on it. Who knows why or how it ended up that way, I think no one really paid attention to that detail until the 1980s.
My late-'65 (L76) has has aluminum covers, one with the casting flaw and one without. One or both could have been cracked and replaced at some point. Just had them lightly blasted with fine sand. They look fantastic.
In 1970 I purchased a set of finned Corvette aluminum valve covers for my '63 from the local Chevrolet dealer for the whopping sum of $11 @... I should have bought a dozen sets!
Back then it was easier to buy these than keep the tin ones from leaking and everyone was doing it...
Yes they had the casting flaw, but as others have mentioned it wasn't as pronounced as it is now.
Good luck... GUSTO
Good luck... GUSTO
valve covers
Good luck... GUSTO
Good luck... GUSTO
Received 1,857 Likes
