zz4 engine casting ID help
I bought a modified ZZ4 engine. Can anyone help me decifer the engine block & head casting numbers?
Engine: 1M0815 3ZZ4
Head: 10088113
Engine: 1M0815 3ZZ4
Head: 10088113
Received 1,857 Likes
That's a 350 4-bolt block, and the heads are aluminum, with 163cc intake ports, 58cc chambers, 1.94"/1.50" valves, angled plugs, screw-in studs, guide plates, and no heat riser passages.
John, Thanks for the info, but I already had that information. I was looking for other information such as:
Mfg Dates
Cam.....I'm assuming it has the spec ZZ4 cam with 208 intake & 221 exhaust. Is it possible that it has the ZZ4 Hot Cam? How can I find out without going into the engine?
I wasn't sure if that information could be derrived from the casting information that I have.
Thanks in advance!
Mfg Dates
Thanks in advance!
