Need Input
Old 11-01-2008, 11:31 PM
GOSFAST
GOSFAST's Avatar
Default Need Input
Looking for any info on an intake manifold for a BBC.
This is a "square-port" setup, single 4 brl., and set up to accept a 4500 carb!
Has "Winters" snowflake, G.M. part #3963647, with a mid-'66 casting date.
Thanks, Gary in N.Y.
P.S. This piece has been heavily modified and MAY have been done by G.M.?
Old 11-02-2008, 12:05 PM
427Hotrod
427Hotrod's Avatar
Received 1,873 Likes on 911 Posts
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Got a pic??
Sounds neat.
JIM
Old 11-02-2008, 02:34 PM
GOSFAST
GOSFAST's Avatar
Default BBC Intae?
Hi Jim, after doing some "measuring" it turns out a Q-Jet had been adapted, probably some sort of "cheater" in some class racing.
Just took the dimensions and it's definitely NOT a 4500 nor does it like like any factory mod!
My son just dropped it off by me, I didn't get a close up look earlier, now I see what was done.
P.S. Still would like to I.D. original application, can't identify that part number (3963647)!! In the photo, the lower right corner has the casting number super-imposed!
Old 11-02-2008, 03:29 PM
rongold
rongold's Avatar
Location: Putnam Valley, New York. Amateur Radio Operator K2NS
Default Not 1966
It's not a 1966 casting, as there are no tapped holes in the coolant runner at the front of the manifold. There are 2 untapped bosses. GM started putting the temperature gauge sending units in the cylinder heads with the 1968 models. I would suspect that the manifold is a service part cast in 1976 possibly for a 454. The service part probably had a completely different part number than the OEM unit it replaced. What is the casting date---you never gave it.
RON
Old 11-02-2008, 05:09 PM
GOSFAST
GOSFAST's Avatar
Default BBC Intake
RON
Hi Ron, there's no choke provision either. No "boss" to mount the choke!
The only piece I have here now to compare it to is an intake from a '69 Yenko resto (#3933163) with a date on the underside of 05 11 9. The same numbers on the bottom of the 3963647 is 7 11 6. I would have to assume this is the date!
P.S. It's most definitely a "high-rise" style intake, not the later "pancake" type!
Old 11-02-2008, 07:02 PM
Grey Ghost
Grey Ghost's Avatar
Here is one that I brought home back in the early 80's from the junk yard. It is a 9-27-65 dated square port. Kicking myself for not bringing more home and stashing them back then And wondering what I left there to be crushed.
Old 11-02-2008, 09:17 PM
427Hotrod
427Hotrod's Avatar
Well that's pretty interesting. Someone sure had their way with that one!
Maybe it is an LS-6 crate intake from the 70's/80's?
JIM
Old 11-04-2008, 09:47 AM
geopar
geopar's Avatar
Default intake
I have the exact manifold, only the plenum has not been cut out, has only one set of carb stud holes, and it is dated 7 16 69.
I sent this info and photos to Joe Lucia (NCRS numbers/parts wizzard) a few years ago, and he could not identify it.
George
Old 11-04-2008, 12:42 PM
53 Blue Flame Brett
53 Blue Flame Brett's Avatar
Default Off Topic...Sort of
I have a friend that has a BB aluminum intake witha 1964 casting date. Neat piece.
Old 11-04-2008, 07:49 PM
rongold
rongold's Avatar
Default Unidentified manifolds
It is very possible that these unidentified intakes are marine items.
Old 11-05-2008, 08:04 AM
427Hotrod
427Hotrod's Avatar
Marine ones usually have the brass insert in the water neck and crossover areas.
JIM
Old 11-05-2008, 08:55 AM
provette67
provette67's Avatar
JIM
the newer ones do but not the older ones that I have seen
Old 09-26-2016, 08:11 PM
bblock409
1st Gear
bblock409's Avatar
Default BBC intake
Hello, Gary. Do you still have that BBC intake you were asking questions about awhile back.
To Need Input
Quick Reply: Need Input
