Steering Box Lube
Any quality wheel bearing grease will work. I use Mobil 1 but Lucas among others makes a good grease for the box. The thing is to not overfill it and attempt adjustment until you're familar with the procedure.
Not going to adjust it ,just want to make
sure it has enough lubrication.
Dave
I was going to add some grease to mine and a buddy was telling me he has seen a tool out there that screws into the bolt hole so you can fill it. Has anyone come accross this or do you have suggestions on how to get the grease in with out getting it all over?
http://www.parts123.com/parts123/yb....Z5Z5Z50000050x
or fabricate your own fitting in 5 minutes with some NAPA parts like I did.
Build you own Get bolt, drill thru center, tap & add zerk fitting
George
George
Great tip, Black Magic!
I just fab'd one of these up, and used up almost a whole grease cartridge filling my two midyear steering boxes. Those babies were dry.
Amazing the helpful info in the service manual, if you just LOOK. Tells you which is the fill hole and when to stop pumping.
Successful day in the shop.
According to shop manual " remove the forward and the outboard cover attaching screws and inject the lubricant in one hole until it oozes out the other"
In other words === here's a picture
George
George
So I guess I'm confused if you have the remnants of the old grease in that 40 year old box and you pump in new grease... Where does all the old filler go.. For some reason I thought grease was made up of mostly filler. So if you pump in some grease it goes in one hole and then comes out another have you really greased the sector shaft and gear?
George
This is probably fine for a box that already is mostly full of the RIGHT lube as you are just topping it off. However, it seems to me that if you want to flush out the old thin oil and replace it with a good, heavier grease then you need to flush the old stuff out a lower side cover bolt hole.
Lets be specific here: The above directions are for a C2/C3 box (er make that a mid year/shark box, no that's not right, make it for the 63 through 82 box).
C1 (solid axle or 53 through 62) boxes have a different procedure and are actually easier to drain and fill. They have a lower side bolt that can be removed and allow the old contaminated grease or lube to drain / be pushed out via the new grease being pumped in from the top fill hole (same type of Zerk grease fitting as above, mated to a pipe plug). Just don't keep pumping past a full cartridge, since a C1 box does not have an upper seal).
Now Tom, do you see where using the C1 "name" is easier to use?
Plasticman
Plasticman
Just a couple of comments. Those zerk screws will work the problem is you don't know the amount you're adding. Going by the other hole is deceptive. Overfilling it will blow out a seal for sure once the box heats up,remember they are not vented. As mentioned if it has any lube left it may be dried out and hard packed the new grease is not going to help much. Also look at the picture and the position of the cover lash screw. If yours is that low in the cover your gears are probably worn out.
Blow a Seal? Not Good...
GTR: you've worried me a bit with that. What do you recommend now that I've filled the box to where grease squirted out the "check" hole?
Should I replace one of the cover bolts with a "vented" one (hole drilled in it)?? MAG
If you look at my box pictures on my rebuilding thread you'll see the inside of the box. Many times the grease may show full when it's not or yes it can be pump up so much there is no room for expansion when it gets hot. Do not install a vent or it will leak out for sure. I leave room for expansion but I fill the box with the cover off and then final set the lash. That's the one thing you have to be careful when removing the cover, getting the lash set correctly on center.
Now in your case you have 2 C2's. They may have been once filled with gear oil and now 40 years later are dry,not uncommon. Look at the lash screw, then get the front of the car jacked up and center the wheels. The steering wheel spoke should be at 6 o'clock, the wheels striaght, and have no lost motion when you turn the strg wheel. Have someone slowly turn it while you check the play. See if there is any up/down play on center as well. ONce it's off center, as in a turn it will loosen up- normal. If it's ok and you have it greased then drive it and see what you get. It's not uncommon for rebuilt boxes to weep a little bit after filling correctly with new grease so you may experience the same thing. It may weep from the adj nut threads, the lash threads, or the seals. Weeping should stop after the grease settles, if you see grease coming out then a seal is popped.
If you have questions you can contact me.
Good luck.
