Best source for v-belts
Who makes the best quality replacement v-belts for C2's? I have had problems with the local auto parts houses private label belts - they either don't fit very well, or they stretch, and one belt actually flipped over (the factory A/C drive belt on my 67).
Are there some brands that perform better than others?
Bob
Bob
The top brands are Goodyear, Gates, and Dayco... Check your local Automotive Warehouse distributor for brands and where attainable at local stores. The general rule is to avoid the chain stores for quality. However Advance may carry one of these brands.
Received 6,530 Likes
C2 of Year Finalist (track prepared) 2019
Best is kinda subjective. "Good enough" isn't: I use whatever belts my local NAPA store sells and they work fine, even on our two track cars (the engines of which see some serious RPM). Never had a problem with the NAPA belts and that's good enough for me.
Jim
Jim
Received 1,858 Likes
I've never had a problem with Dayco "Top Cog" belts in high-rpm applications; any belt will have issues if the pulleys aren't properly aligned, and the factory didn't go to the expense of deep-groove pulleys on solid-lifter engines for nothing.
Compressor Belt
On my '65 300hp A/C P/S car, I went with NAPA XL25's on the water pump and alternator belts (good product), but the compressor belt needs to be wider -- 15/32 top width.
For that belt, the DAYCO top-cog 15565 was the closest fit. Was glad to read that John H. has had good experience with the top-cogs!
