Powerglide ID help?
Powerglide ID help?
I have a cast iron powerlide transmission that came with a 1960 Corvette I purchased but I don't know if the numbers on the transmission are correct for a Corvette, can anyone help ID this transmission ? thanks bill
Powerglide numbers case on bottom 3784867 GM14 H30
Large side cover passenger side 3771724 GM 8 H30
Dipstick cover passenger side 3708096 3G
tailshaft 3777289 GM 17 O
small side cover driver side 3719251 GM 48 G 280
I'm not into numbers can you post a pic of both sidea and the TC.
There basically all the same inside, out side the tail housing Corvette needs a shifter mount , some have a modulator , convertor Corvette has 35 bolts and so on.
Power glide
Just wondering if you still have the 60 power glide . My car is in need of one.
Thanks Katch
Here are the part numbers on the PG in my Dec. 59 built 1960
Main case - 3742348, date J 14 9
Pass. Side, large cover - 3771724, date J 16 9
dipstick cover - 3709096
tailshaft - 3726595
Low/Drive valve cover (driver side) - 3719251
tailshaft - 3726595
Power glide 60
Thanks Katch
Power Glide 1960 Vette
Hi Bill, I have a 1960 passenger power glide that I am trying to convert for my 60 vette.I have been told that the outer case is the same except for the tail shaft. I am contemplating on buying a 1961 corvette power glide and transfer the guts into my case. I guess if the only difference between a 60 and a 61 are numbers I could just rebuilt it. Not looking for numbers matching but what it would look like after it left the factory. You said when you bought the car it came with a power glide. Is it in your car or was it an extra tranny and if so is it for sale. Thanks for the numbers , I need to see if any are on my case for curiosity sake.
Thanks Katch
Conversion
Sorry 3310Vette... I didn't intend this message to go to you. But would be happy if you did have an opinion on my message. Thanks, Katch
Thanks Katch
Thanks Katch
I am not certain if you can convert a passenger car PG to a Vette PG by just replacing the tail shaft, but I know a man in Dallas that can answer your questions and probably get most any PG part you need. He helped me obtain parts and seals for my 1960 Vette PG. If you want his name/phone number, send me a private message.
Joe
Joe
Buzz from Texas
Thanks Katch.
