Help with R&R A drive shaft
I know that R&R a trans has been discussed several times but I did not notice dive shaft removal discussed at much length! To change out the 4 speed in a 64 am I going to have to remove the drive shaft? And the drive shaft removal is this is done at the rear u-joint, right? In order to get the drive shaft to turn to loosen all 4 nut on the rear u-joints do I place a jack under each trailing arm and jack them up to free the wheels so the drive shaft will turn? It's a tight fit at the rear u-joint! Thanks for all answers. I am trying to remove all surprises before starting this under taking.
1. Jack the car up and disconnect the parking brake. To disconnect the ebrake just pull on the lever under the car near the ds and the ball from the ebrake handle will be able to pop out of it's captive slot. Then rotate the ds around until you can get to two of the u-joint strap nuts. I believe that they are 1/2" nuts, if you have some of the ratchet wrenches it makes this a breeze. Put the car in gear so that the ds doesn't rotate while you break the nut loose. Then pop it out of gear and rotate the ds until you can get to the remaining nuts.
2. With my car being a side pipe car and no tire tube installed I can easily get to the diff u-joint. Then for the front at the tranny I jack it up just a little bit. I can have one in and out in about 30 minutes... Not bragging thats just how long it takes..
Dave
Received 1,857 Likes
After doing the rear as Dave noted, you need to remove the U-bolt nuts at the trans yoke, push the yoke all the way into the trans for clearance, and pull the prop shaft out from the front. Wrap tape around the U-joints first so you don't lose the caps and needles while you're removing the shaft.
The easy way is to use a ratchet wrench. Place the wrench on the nut and rotate the wheel to apply pressure to turn the nut. Then just keep rocking the wheel back and forth to operate the ratchet. You do have to get the wheels off the ground. Easy on a lift.
I took the 4 speed out of my '63 saturday afternoon.The drive shaft is straight forward.Once you have both ends unbolted take the u-joints cups off.I couldn't get tape on them because it's tight in there.Not counting the time it took to raise the car on jack stands,it took 2 hours and ten minutes to get the 4 speed transmission out.
I am going to put it automatic.Is that what you are doing?Maybe we can swap shifter ideas.
Howy
Howy
