Correct Speedometer gear for '67 Question ?
I have a M-21 transmission in my 1967. My father said its a 31 spline but I think he meant 32. The rear end is 4.11. My tire size is 215/65R 15. Which speedometer gear should I be using(color/#of teeth)?
Can anyone help me.
Thank you,
chris
Can anyone help me.
Thank you,
chris
Not good
You have a 1.84 diameter gear in the trans with 8 teeth, that's all the make for the 32 spline unit. There are reduction units that were made, lot of those on GTOs. I don't know if any of those are still available.
Muncieman,
Would using a 24 t gear with a ratio adapter of 10% slow down rate work?
thanks,
chris
thanks,
chris
I think you are on the right track. The 26 tooth gear is not perfect, it's 2 % off from the jump. Those short tires and that tall gear must be fun
I'll post what I find tomorrow.
