Marina Blue paint?
Old 12-09-2008, 07:25 AM
70/99rdstr
70/99rdstr's Avatar
Default Marina Blue paint?
I'm restoring a 67' Marina Blue coupe. I'm having trouble finding an exact match for the color. Does anyone have the PPG or DuPont code or mixture for a "correct" Marina Blue? Thanks
Old 12-09-2008, 09:32 AM
wombvette
wombvette's Avatar
There probably is no "correct" match, even if you find it in lacquer, so use your best offset. PPG usually does a pretty good job of supplying an offset color. If you can find a car done in what you think is the correct color, you can take that to the paint store for a computer match, but dont hold you breath for anything exact even then.
Jrs66vette (10-28-2019)
Old 12-09-2008, 10:01 AM
66since71
66since71's Avatar
Dupont has formulas for their latest paints for the original colors. The new paints use the same codes as the old. I have a chart somewhere, and will post the 67 Marina Blue's code as an edit here later.
Harry
edit: try this link
http://www.corvettepaintcodes.com/
To Marina Blue paint?
Quick Reply: Marina Blue paint?
