Rear spindle bearing lube?
I have seen on many corvette vendor sites a rear spindle grease tool. The copy indicates that it will be easy to lube your rear bearings. Instructions are included.
How do you lube the rear spindle bearings? Does this tool work?
Your comments would be appreciated
Jack
Jack
About the only thing these tools do is blow out the bearing grease seals. They will only get grease into the inboard bearing and the outboard bearing gets nothing. When the cavitivy gets full of grease(not recommended by anyone) the seals are pushed out of the housing.
Regards.
Page Campbell
Regards.
Page Campbell
Received 1,857 Likes
