1956 Grille Tooth Sequence
I have a 1956 Corvette and a lot of individual mixed up grille teeth (from who knows what years) and want to use the correct configuration. They seem to have a code (no part number) on the inner backside that corresponds to the length/shape. I see "C" assume center. Also "1", "2', "4", "5", "6" but do not see any "3"s. The repos only describe 5 different teeth so I am really getting confused. Any one know what is the correct sequence for assembling on bar? Thanks for any help.
I hope that made some sense.
That diagram helps explain my confusion. I did find a "3706425" on some marked "2" and they are the same physical dimensions as the ones with a "1". I assume the "1" and "2"s (missed marked?) are interchangeable in the first 6 positions either side of the center. Thanks for the input.
