62 plug shields and wire routing question
It appears I am missing something from my 62's ignition shielding. Did all 62's come with the four inner plug shields? I have the 2 outer plug shields which bolt to the L brackets held by the exhaust manifold bolts. I was also wondering about plug routing. I see there is one clip on each side using an oil pan mounting bolt. It also appears that there is one clip on each side that is either mounted to one of these inner plug shields or the block itself. Thanks to anyone clearing this up for me. Have to know how many and what to order.
Bill
Bill
Received 1,856 Likes
Yes, all 62's used the four spark plug heat shields, and the front two plug wires on each side use a 2-wire vinyl-coated clip attached common with the spark plug heat shield bolt on each side.
I could use a pic of this if anybody has one. I've had my front two wires on each side plastic tie-strapped off for a year now because I didn't know where they were secured...
