how to check cam lobe for wear??>
without taking intake off on motor how can I tell if cam has wiped lobe, this is on big block solid lifter cam. thanks.
pull the valve covers and look for a valve that does not move or moves less than the other rockers as you spin the mill....good luck...why do you ask? what are your symptoms??......
some of the rockers loosen up after driving/running car for short time (less than 1hr total time) and need adjusted again ...solid L-71 cam...new rocker studs, new rocker arm nuts,
new motor with less than 3 hours on motor, broke in 2500 rpm for 30 minutes without issue, changed oil and readjusted valves, set timing etc. after brake-in.
use a dial indicator!! of course you can use the eyeball method (are all the rockers/ valves moving equally??) or the noise method (if you have clacking and the rockers are moving in different amounts, your cam is going flat) i have seen cams go flat to where the bottoms of the hydraulic lifters had a hole in them (yes. they were very dished shaped as were the cam lobes)..
the press in rocker studs were from the 60s (and 70s smogger heads) on small blocks, or the 60s fuelly/camel hump heads, the ultimate heads(the fuelies) at the time would pull the pressed in studs out with increased valve spring pressure. in the old days we would just pin them. that is drill through the stud boss and install a roll pin through the stud and the boss to keep the rocker stud from pulling out. i have seen many pressed in studs pull out with stronger springs, but never with roll pinned/pressed in studs. but who cares? now all heads have screw in rocker studs.
One thing to check is the heads of the valve stems. Since engine is fresh, it is probably cam wear, but those symptoms are exactly what you get if a valve is loosing a keeper. Big blocks were notorious for this, back in the day, and I saw it happen too many times. Happened to me once.
I had a friend that had the exact problem with an L88, and he decided to drive the car home, and call me in the morning. On the way home, the engine dropped a valve, and ventilated the block. Another friend with an L78 caught one just in time, by chance.
I would check the valves before I ran the engine again. Just look carefully at the side of the rocker, where it meets the valve. The valves should all look the same, and have the same amount above the keeper. Rich
When I bought my car it had a miss in it that I could not get rid of. That caused me to pull it apart and I found that there was two lobes down on the cam. If the valve train is OK and the adjustment on the valves hold and you still get some type of miss in the engine, then I would suspect a flattening cam lobe.
Exactly. They are so cheap now you can't afford not to have one. Grizzly Industrial has one with a magnetic base for $21.95.
http://grizzly.com/products/Magnetic...-Special/G9849
You can buy a cam checking tool from Summit or Jegs. Not real expensive
Proform #PRO-68902 - $76.95
Summit #SUM-900132 - $55.95
Proform #PRO-66830 - $61.95
Search the sites for Cam Checking Tools
screw in studs.....mechron had a wiped cam with holes in lifter bottoms on 396/350 camaro back in the day, funny thin ran fine with power and no noise, discovered on taking it out to put in mechanical cam, original owner I got it from always used conoco oil ... maybe that was why
I will check valves in all ways suggested and will do final check with dial indicator and last choice is pull cam and check thanks for help guys. will get back when I get results, have to put differential back in first so I can move car.
