Advice for repairing fiberglass gas tank
Any and all suggestions will be appreciated. Plan on removing the tank, doesn't leak unless the tank is about half full.......
Thanks,
Thanks,
I'm told, but don't personally have proof, that the newer ethanol-based fuels eat away at the lining in these old tanks....so if its leaking in one place its probably weak in others.
I don't mess around with flammable liquids or vapors so I'd personally replace it. wmf62 (Bill) on this forum has replaced his and he can tell you where he got his from if you will consider that...
Frank
Frank
St. Jude Donor '07
Frank
Frank
he said 'fiberglass' tank.. and the only OEM fiberglass tank i know of would be the BIG tank.
if it is a fiberglass tank and it is leaking from something other than a obvious hole, then i would suggest one of two things:
1. replace the tank. there are supposedly repros available
2, get some of the 'pour on the tank' sealer stuff they use for metal tanks and work it around the entire inside of the take so that it is completely lined with the sealer.
if it is a metal tank, then there are replacement metal tanks are available from a number of sources other than the corvette vendors. just do a Google search. mine was made by Spectra and is available many places.
Bill
Bill
Good advice - if he has the 24 gal 'big' tank he has a rarity indeed...
Bill - I don't think the sealer would work in a fiberglass tank. If the tank is leaking it means it has a crack or split which will only keep getting bigger in time. The sealer would not flex enough to prevent that. Only correct way to fix a fiberglass tank would be to repair it with fiberglass.
If a metal tank, then just buy a new one, its more cost effective in the long run. I bought mine from Corvette Central
Yes, this is the 36.5 gallon fiberglass tank, I just wondered if someone
locally has experience with this type of repairs.....
I thought about checking for over the counter sealants.....not sure if that would only be a temporary fix........
2021 C1 of the Year Finalist - Modified
My 66 Racer had the big tank in it. It was notched out to clear the roll bar and fiberglassed back together. No big deal, just looked like regular fiberglass mat and resin. I ran high octane racing fuel in it.
Pops
Pops
fix what you can with glass then use the epoxy sealer from these guys http://www.caswellplating.com/
Can you tell if it's leaking at a seam, or at another damage point where it has a crack or split?
If it's leaking at a seam, it might be worth trying to see if it will come completely apart at the seam. That'd let you properly re-bond the whole thing at the seam without messing up the tank. If it's a seam, I'd think chances are good that it'll continue to separate at the seam over time.
If it has a hole or other damage, you might be able to repair just that area.
If you should choose to use one of the coatings for the interior, be sure you get the type compatible with ethanol gasoline, there used to be two types available. My experience with this stuff (Por 15, specifically) is that it's pretty flexible and durable, it'll seal some pretty good sized holes, up to at least 1/8" diameter. I've used it on old motor scooter tanks that have been rusted through, not a leak to date. But, once you put the stuff inside the tank, it's there to stay. Be sure you take that into consideration.
(They even tell you in the instructions that you may have to drill out or otherwise open the gas line connection into the tank, as it'll get sealed over as well in some cases. These are 1/4" to 3/8" lines, but a drill bit makes short work of opening these).
Whatever you decide, remember you're working around a potential bomb, an old gas tank with fumes inside. Power tools can cause an explosion or fire from the sparks between the brushes and commutator.
Received 1,857 Likes
You might check with a marina - many boat tanks are fiberglass, and they'll know what resins work.
Once the inside is thoroughly coated, pour the excess out and let it cure for a period, about 24 hours as I remember.
Eastwood is one of the suppliers that handles the stuff, there are plenty of others as well. I'm sure you could go to the "Hemmings" online site and find some advertisements for suppliers as well.
My only concern is the fuel line fittings being pluged with the coating inside the tank, since i can't remove them without doing damage to the tank.........
Are you serious?
I dont quite understand this one. You have a tanker and you are looking for a cheap way out to do this repair??? Splash around an inside the tank sealer and cross your fingers?
No offense, but get real. Is it worth taking a chance on getting it wrong? Whats the worst that can happen - Oh, nothing serious except maybe fuel leaking, catching on fire and your car burning to the ground.
GET PROFESSIONAL HELP NOW!!!
As john z said - get to a professional fiberglass or boat company that does serious repairs. This is no time for shortcuts or cheap fixes.
bigredbrad
bigredbrad
The fittings just thread into the tank so they should be able to be removed with no problem. Once they are out I would install plugs in the holes so the coating doesn't mess up the threads. If you decide you need a whole new repro tank let me know.
Frank
Frank
