SPEEDO CONVERSION : from mechanical to electronic??????????
Hello ! I liked to convert my 1963 mechanical speedometer to electronic (like autometers etc) Have you ever heard or know someone who can do it?
thanks !
thanks !
Re: SPEEDO CONVERSION : from mechanical to electronic?????????? (bowtie racing)
Are you certain you mean "speedo" and not "tach"?
I understand why someone would want an electronic tach in order to make use of a later model HEI distributor (without having to purchase an aftermarket HEI with a mechanical tach drive), but why in the world would you have need of an electronic speedometer?
For all intents and purposes, the tach can serve as a speedometer in high gear since the needles move in synch with each other.
Re: SPEEDO CONVERSION : from mechanical to electronic?????????? (waynec)
Hello Waynec
I want to get rid of old cabledriven Speedometer and my trans comes with elecronic output only.
has anyove ever tryed to use Autometer components with original face?
Bowtie- good topic, I too am curious. My 66 is getting a T56 6speed soon, and it has an electric speedo drive. I know that JTR has a conversion kit, for about $350 or so, but I was hoping to find a cheaper alternative.....
Hope someone has tried this!
Matt
Matt
I know this is an old thread, but I'm curious if anyone found a shop that would convert a 63 speedometer from mechanical to electronic, and how it turned out?
I've asked the following shops and received a "no" on a request to do an electronic conversion:
1. Corvette Instrument Service
2. Williamson's Instruments
3. Red Line Gauge and Clock (TN)
Redline Gauge Works (CA) said they could do it, but the person I spoke with on the phone didn't give me a lot of confidence he understood what I wanted...
I'm doing a T5 WC conversion with a VSS output and I'd really like to keep the look of the stock speedometer and prefer a conversion to electronic. I know about the cable X, it is my last resort. I'd rather spend that kind of money on a converted speedometer.
I have a 63 instrument panel at redline ca. They are backed up but Shannon the boss said he could do it, I left the panel and a deposit (required). Hope to get it back within a month. If you are in a hurry find another place.
I have converted a mechanical tachometer on a '62 to electric by using Autometer "guts" and an original tach face plate and needle, not a great problem. I would guess that the major problem with converting a speedometer is the location of the mileage and reset odometer.
Another option might be be to use a Cable-X unit ( http://www.abbott-tach.com/cablex.htm ) which converts an electronic signal to mechanical. I have used several of these units to drive mechanical speedometers in cars with newer transmissions having electronic outputs, and they work fine. I was told that the Cable-X unit could drive the speedometer using the signal from a GM EFI unit, but I have never tried it. Not sure if it would work with a points type ignition. The Cable-X units run about $400, and I would suggest you contact their tech support to insure that the unit would work with your particular setup.
Charles
Charles
Or.....
Dakota Digital...
http://www.dakotadigital.com/index.c...rod/prd858.htm
Direct fit to your front Bezel One cat 5 cable....By By Speedo and Tach cable.
Comes with all sensors and electronic speedo converter. Screws right on the 4speed housing.
Working on mine now
Dakota Digital...
Working on mine now
Thanks for the replies.
Roger - let us know how your speedometer turns out from Redline Gauge Works.
VNV - I do like the looks of the Dakota gauges, I just prefer the stock look for this application I'm working on.
I also found that Corvette Clocks by Roger can do this conversion and keep the manual odometer. He also offers a GPS conversion to the stock speedometer, as well.
The Dakota Digital also offers a GPS optional unit that works with their dash..and can be used in other ways.
http://www.dakotadigital.com/index.c...rod/prd837.htm
Read all the text..Just..FYI
I will reply about my speedo from red line when I get it. BUT that's going to be awhile.' I'm at least a month from getting the car back from the painter. Then comes full assembly. I fit a ls3 525 hp GM connect & cruise before I sent it to the body shop. But when I put everything together I'm expecting at least a month hassle getting a/c system installed. I had dirty dingo make me some different a/c bracket plates , I' m trying to keep a sanden compressor under a stock hood. I bought a second hood and am having it fit and painted in case I have to modify the structure during assembly. My original plan was to keep all factory parts on a shelf so that if my wife ever decides to dump it. It could be restored with out much headache. We have 7 corvettes among our 30 cars
I guess I should add that I SURE I will be happy with redline. I visited there shop to drop off the corvette & 47 cadillac parts for upgrade . The names on the shelf were the whose who of this hobby. Me being unknown to him. I had a friends wife (friend passed away) that restored cars for pebble beach & black hawk museum among others. Pick up the caddy parts but still awaiting the vette stuff, to slow down any cutting in front of me. And I WANTED TO KEEP THE INSTRUMENTS APPEARING ORIGINAL. These guy have to many people waiting inline to be Mickey mouse
