Cast date missing?
Cast date missing?
my 66 427 390 has the correct cast number on left rear but on right rearis "hi perf" cast but no cast date that I can see. Any idea of what I'm looking at? Thanks
B/B Casting Date
Someone correct me if I'm wrong, but isn't the casting date on a 427 on the side of the block near the starter ???
RON
knight, it was built december 65. i never knew what was considered the cut off for "early". if it's not "early" where else could i find the cast date if not on the right rear opposit the cast number?
also, since "early" is mentioned in regard to the indented passenger side valve cover ( i have factory a/c) knowing the "early" cut off date would help me there as well.
Thanks for all of your help.
The air conditioning "dimple" ran from early (November 1965) to mid ( January 1966).
Of course it was not needed and then deleted.
At least that what the Judging Manual states. (Fourth Edition)
I have an April car and it has the dimple in the passenger valve cover.
I have a 1968 block with the date on the side (by the starter) of the block.
[QUOTE=
I have a 1968 block with the date on the side (by the starter) of the block. [/QUOTE]
Yes, it carried on into 68 with the 427s, but after 67, who cares?
