power brakes on 67 small block
I was thinking of adding power brakes to my 67 anybody know how difficult that is, is it just a matter of adding the booster or is it more complicted than that. Any help on this matter would be appreciated thank you ditchdigger650
power brakes
I added power brakes to my vette and it was pretty easy. Bought the booster and master cyl new from Classic Performance Products on a ebay auction for $110. It is not correct for the year it is a 68 MC but there are other things I changed so no big deal to me. I painted the MC Chevy Orange to match the engine and I thought it came out nice, but thats my opinion. Works great.
I'm pretty sure you need a different set of lines because of the different location of the master.
Note the two different brake line part numbers from Paragon...
http://www.corvette-paragon.com/p-35...ne-kit-pb.aspx
http://www.corvette-paragon.com/p-35...kit-wo-pb.aspx
First, please fill out your profile so we have a little information about you and your car.
You can easily add the brake booster and use your existing lines. All you need is a 9" extension for the rear brake line. There is plenty of flex in the front line to rebend it. Check out my pictures and the little write-up I did ==> here.
Roy
Roy
i actually went from power to manual many years ago ...went with a stainless steel brake m/c with a 1" bore and love it...i dont have toe touch braking, but like it a whole lot more.. maybe you have some other issues that are un covered with the present set up??......to each his own...jmo...
