Turn signal switch
I wrote instructions on my 65, let me see if I can find that post....
Found it
http://forums.corvetteforum.com/1569389099-post3.html
And later confirmed to be accurate
http://forums.corvetteforum.com/c1-a...al-switch.html
Found it
Found it
Found it
Dennis
After you get the switch installed I have found its a good idea to jack both front wheels off the ground and thoroughly check out the brakes/tail lights, signaling functions and signal canceling action backed up against a reflective surface to see the rear and turning the steering wheel in both directions while signaling. Otherwise, you find out things are not quite right on the road....
