U-Joint Question...C3 rear in a C2
Need a little bit of help installing my driveshaft, guys. I have a 74 differential in my 65.
I rebuilt my stock 65 driveshaft a while back with new u-joints, getting ready for the motor drop.
Today, I lowered the motor and trans (the stock 65 M-21) into the car. When I started to bolt the driveshaft to the differential, I discovered that the U-joint is too small for the front yoke of the differential...it is not wide enough to fit snugly between the tabs that center the u-joint. The diameter looks fine.
How has anyone dealt with this problem? Is there a u-joint available that has the dimensions of the 65 driveshaft on one side, and the wider 74 yoke on the other side?
Thanks in advance
Joe
Thanks in advance
Joe
Received 6,521 Likes
C2 of Year Finalist (track prepared) 2019
Head to a NAPA store and ask for part number 353. This will get you a hybrid U-joint that is a 1310 on one cross and a 1330 on the other.
Jim
Thank you, Jim! Glad to see it isn't a big deal sizing things up.
It's just what I was hoping to hear; you made my day.
Joe
Joe
Glad to help, Joe. Good luck.
Jim
Jim
