Power steering fluid; which one?
St. Jude Donor '06-'09-'10-'11
Hello, All,
I cannot find an answer to my question in previous posts so I'll try to get one this way. I am restoring a '66 and I rebuilt the power steering pump and have new hoses in place. Now I am going to add fluid and I don't know which one to use. The shop manual says to use GM power steering fluid, or, if that is not available, trans fluid Type "A". The (original) cap on my pump says to use trans fluid Type "A"; it does not mention PS fluid. Any suggestions?
Thanks,
Jim
Thanks,
Jim
Larry
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
Red for G.M. and yellow for Ford, in the old days anyway.
Received 1,856 Likes
The shop manual was written 45 years ago, and none of those fluids have been available for decades; use GM or any other current power steering fluid or Dexron ATF; they're all backward-compatible.
I think you should advertise for some new old stock. The changes in formula may cause you demerit points.... and we won't have anything to do with that.
Your really serious ???????????????
