oil pan gasket leak fixed!
I have battled an oil pan leak at the timing cover for a long time. I tried new gaskets and even a new oil pan. Maybe this is old news but I heard about the FelPro Perma-Dry one-piece gasket and decided to give it try. Its not cheap ($30) but my oil leak is history. This is by far the best gasket, period, and Ive tried other 1-piece gaskets. It even came with new bolts and "hangers" that screw into the corner bolt holes to hang the pan and gasket while you install the new bolts.
Hello
Glad to hear this I bought one a while back and I am waiting for a time when I can go through the engine and use it...Yes its pricey but if it stops the dreaded oil leak...Its worth it!
I just replaced my pan gasket. I ended up using the original type 4 piece gasket, and about a 1/8" wide bead of "The Right Stuff". No leaks! The Right Stuff is the best gasket sealer I have ever used. I also used it on my intake manifold and thermostat housing with no leaks. The only drawback is the directions say to mate parts within 5 minutes.Kinda hard to due on a large piece like a oil pan or intake. I was going to use the FelPro one piece on the pan, but I couldn't handle that blue color.
Those one-piece pan gaskets are nice....but...i found out the hard way that you need to get the correct one for the timing gear...late or early...there is a thickness differnce that i was unaware of...
jack
jack
Had a small oil leak(2-3 drops/ ride), decided to install the one piece blue gasket....now I have the Corvette-Valdiz on my hands. Will be switching back to the four-piece gasket.
The instructions said to use a small amount of RTV where the timing cover/block/pan meet and where the rear main meets the block. I used Permatex Ultra Grey, which Ive had great success with on intake, thermo housing etc.
It usually requires putting some sealer at the corners, with that being said if you have a major leak after changing it I would inspect where the leak is and suspect that the timing chain cover could be part of the problem.
Dave
On the old gaskets its the "smile" piece of the gasket that usually leaks is it not? On the new one piece gasket is this problem eliminated?
Received 1,856 Likes
Production pans prior to '75 used the "thin" (0.29") front seal. Production '75-up pans (and ALL Service pans manufactured from '75-up, regardless of their intended application) used the "thick" (0.41") front seal. Fel-Pro (and GM and others) make that molded gasket in both flavors, but you have to know which pan you have before you buy the gasket, and aftermarket pans are a crapshoot - they come both ways.
Determine the front seal surface radius by measuring from the pan rail flange surface (no gasket) to the 6 o'clock position on the seal surface. If it's 2-1/4", it takes the "thin" front seal; if it's 2-3/8", it takes the "thick" front seal.
If you use the gasket with the "thin" front seal on a pan that requires the "thick" front seal, it'll leak like a sieve at the timing cover, and all the RTV in the world won't stop it. The same is true with most of the Taiwan chrome timing covers - the seal flange on that junk is spot-welded to the cover, and they'll leak; the original GM timing cover had that seal flange continuously roller-welded, and they won't leak there.
You can't just "buy a pan gasket" - you need to know which one you need first.
