Vent window rivets.
Vent window rivets.
Just replaced the rubber weatherstrips on my vent windows. Now need to reinstall the vent window hinge pin. Got 2 plus a spare a spare from Vendor. Any advice as to how to properlly rivet?? The rivet is the type with a hollow center. Thanks Dave
I did a respectable job with a BB (for a BB gun) sitting in the hollow end, crimped carefully with a pair of Vise Grips that I had padded the jaws with a few layers of tape. If you decide to try it, crimp slowly so you can see what's happening to the crimped end of the rivet.
If you've got a spare, you might want to give it a try . . . up to you.
I drilled the old out, rested the head side of the rivet on a piece of iron and used a hammer and punches to widen the barrel end of the rivet. Started with a small punch working up to two larger punches.
Vent window hinge rivet
To properly set those tubular rivets. I got a hand rivet squeezer and roll chrimp dies from Hanson Rivet. Not inexpensive. Hand rivet squeezer was about $165. The dies where only $12 to $18 each. I also got the dies to set the rivets on the weather stripping for the side window. You can't order over the internet. They do have a website. Must call them. To make things go quicker for ordering have all the dimensions of the rivet. www.hansonrivet.com
Wendell
Wendell
Wendell
Wendell
Tried the BB method but was not happy with the finished product. Started over with the $12 (I think) tool from LICS that looks like a punch and it did a much better job IMO of rounding the finished flare on the rivet. Pilot Dan
http://www.parts123.com/parts123/yb....Z5Z5Z50000370a
Good ideas guys. I bought a spare just in case. Bought my rivets from LIC and wish I had see there tool. After reading your ideas it got me thinking. Wonder if a tubing flaring tool would work??? Got to go check that out . Thanks Guys.
LICS has 3 rivet setting tools is this the one?
