Spring Removal J-22944. Any interest?
Received 3,218 Likes
For those of you that have messed w/ the "free" tool loan at the local Auto Parts place-and then had to purchase the tool because you destroyed the chinese junk- This ones for you!!!
If you have ever tried to replace an original or Big block spring -you know the headache of the threaded spring compressor-won't compress enough and then the "fingers" get caught between the coils and impossible to remove....
I knew there had to be a better way- The "J-22944"
After looking at it- Did a search and they were nowhere to be found.
Hence- the idea to make a "New and Improved" one-
I whipped this up at my buddies machine shop w/ some scrape metal laying around.
I improved it by adding a fitting that'll go right in a standard floor jack-
Here's what it'll look like in action-
Any interest? I can make several more. Price? It's got to be a lot quicker than the threaded spring compressor.
Ideas to improve it? I'd put a cut heater hose over the A-Arm cross shaft to protect the paint/powdercoating..
Richard
Richard
Richard:
I like it! Not certain if my old HD floor jacks have the removeable saddle. They probably do, but they seem to be locked in somehow. Maybe a snap-ring or lock-ring. I need to checkout....including the hole size/diameter.
I would be interested in the $$, since I plan to rebuild the fromt end of my 1967 next year. Rear suspension was this year.
There was a guy on the forum that developed a tool to remove the dents from the front frame crossover a few years ago. He went on to market and sell his invention. You may consider following. I don't think GM or Kent-Moore will have a problem with a tool this old, but that could be an issue if you go commercial. Keeping a small distribution should not be a problem.
Larry
Larry
Not sure about BB springs. My small block springs didn't even require a spring compressor. Just removed the upper ball joint nut and lowered it with an A-frame screw jack. Hardly any tension.
Thanks Larry-
I've got another aluminum "Racing" floor jack- It just has a couple of pins to remove the saddle. It works fine on it as well-
Texan- Sounds like you have an aftermarket/non-original spring. The originals even for the small block are a lot longer and have a lot of tension.
Richard
Richard
Thanks Larry-
Richard
Richard
