Torque Specs - rear drive & suspension?
hi guys,
i've checked the popular reference sheet from magicV8, but i can't find:
torque for rear bearing carrier to trailing arm bolts (4)
torque for prop shaft bolts to rear bearing (4)
also wheel torque - i've changed to 15x10 in the rear for my LS2/TKO project, wondering what a proper torque should be given that i suspect the original 60 ft-lbs call out isn't enough for this modified C2 with aluminum wheels.
thanks,
thanks,
torque chart in help section near the bottom of my web page
http://home.mchsi.com/~magicv8
most tire stores torque new aluminum mags at 90-100 lbs/ft. Otherwise, ask the manufacturer.
