need advice - distributor/rotor orientation
Here are the particulars.
1964 283 stock 4 barrel engine with a stock single point distributor. Engine has run well over the last few years.
The plug wires are in their proper orientation as is the distributor, rotor and cap.
I've spent some time installing the distributor, rotor and plug wires in their proper orientation. Disconnected the vac advance and fired up the engine. It ran like crap but it did run. I set the dwell at 30 degrees and checked the timing, which was well AFTER tdc, so I rotated the distributor counter clock wise and this is where the problem is....the vac advance can hits one of the intake runners when the timing is exactly at tdc. I can't adjust the timing to before tdc because of this interference. I think my rotor is off by one tooth, the question is: which way do I rotate the rotor? I think the rotor should be rotated back (counter clockwise) one tooth. Is that correct?
Received 1,857 Likes
Moving the mainshaft one tooth will move the distributor housing 28*; if that puts the advance can into the plug wire support, you'll need to pull the distributor and move the drive gear 180* - that will move the distributor housing 14*.
Received 1,843 Likes
You're looking to move the distributor housing (and vacuum advance can) further clockwise to get the can away from the intake runner, and the rotor tip needs to follow the distributor rotation, so the rotor (mainshaft) needs to move clockwise.
i called midyear today about this. good timing. i am confused. i thought
moving the distributor counter clockwise advances the timing. jim aka always confused.
Timing
RON
jimmy....counter clock wise advances the timing if you are moving the housing....did you get it fixed??...if not , call me and i will move my schedule around tomorrow to come over and fix that puppy up......
Exactly how I do it...never had a problem and beats breaking your back leaning over the fender probing around with a long screw driver in the distrib hole trying to get the oil pump slot lined up!!
frank go make big bucks so WE can spend those big bucks. i will get it
tomorrow. thanks jim
no problem no problem no problem no problem no problem..............
Turning the distributor gear
Thanks John. I'll try walking the rotor/main shaft clockwise one tooth. I've gotten pretty good at "walking the rotor" and getting it to align with the oil pump. Really don't want to pull the entire distributor to rotate the drive gear 180 degrees if I don't have to. Is that something that is simple and can be done at "home" or will I need to take it to a machine shop?
RON
I had to rotate mine 180 degrees simply because I installed an Edelbrock Performer RPM manifold.
Seems that the #8 runner on the stock 300 hp manifold sits much lower and is indented for the distributor, as the Corvette manifolds are and this is right where the nipple aligned. One tooth the other way and it hits the shroud supports.
[QUOTE=rongold;1573912413]If you're mechanically inclined, it's a simple job. All you need is a hammer and a correctly sized punch and a solid surface to support the tail of the gear. Drive the roll pin out, spin the gear, and reinstall the pin. It's easy if you've done it before, a little scary if it's your first time, but there's ONLY 1 first time--After that it's simple.
Thanks, Ron. Doesn't appear too complicated. But I think, since this was a passenger car engine and when it was built no one had to worry about ignition shielding or shielding supports, I may have a pretty good chance of having to rotate that gear. We'll see this weekend.
RON
Houston, we have lift off.
Rotated the rotor one tooth clockwise, had enough room between the intake runner and the shielding bracket to set the timing to about 10* tdc. Dwell is at 30*. Didn't have to rotate the gear 180*. Life is good.
I do have one other problem before this old war horse returns to the road. I'm dumping a lot of gas into the crank case. I've started another thread asking for advice on this problem.
Thanks to all who helped me with this timing issue.
