Thinking about BF Goodrich Radial T/A tires mounted to knock off rims
Hello
I was thinking about replacing the white wall tires I have in favor for the BF Goodrich radial T/A tires...I was wondering what tire size is good with aftermarket knock off rims
Pete
Pete
I've used 215-65x15's on two midyears with the 6-inch KO's and two other midyears with 67 Rally Rims, also 6-inches wide and while they are a bit shorter than the equivalent stock size was, they fit very well, no rubbing and a nice contact patch size.
Mike T.
Mike T.
Received 1,843 Likes
Hmmmmm
I kinda like the raised white lettter thing on the midyear... Unless someone wants to donate some gold line tires for me to put on my K.O.??
Ray
If buying a set of new tires for you C2 coupe with knock offs what kind of tires would my fellow forum members go for?
White walls 20/75/15 as original? That is what i have on my car today.
Continue using white walls 205/75/15? Open for suggestions
Man - I don't see a THING wrong with keeping exactly what you have
I like the TA radials. I have three sets mounted up and on cars. Two of them are on Novas/rally wheels and one on a modified Corvair with aluminum rims.
I just think the white letters against the Corvette hubcap compete for visibility too much with each other. I had blackwall tires on my '65 coupe with hubcaps for 30 years. Never did like it so I changed to KO's and gold lines. Made it an entirely different car, visually.
Can somebody post a close up picture of a C2 with white lettering?
A little more close up than the picture Donny Brass posted.
I think its kind of okay with the letters
The problem with white letters are that it looks like a whitewall when moving or spinning. And my wheel below is the Dayton wire knock-offs 15X6 wheels with 215-65R-15`s Goodyear GT tires. .......
