'57 Oil Capacity
Old 06-12-2010, 11:34 AM
arizonapete
arizonapete's Avatar
Default '57 Oil Capacity
Changed the oil & filter in my '57 ~ Added 5 quarts (1/2 quart in the filter canister), and it hardly showed on the dipstick. Yet all the spec info I can find says 5 quarts...
Looks like its down two quarts....
Is 5 correct?
Old 06-12-2010, 11:51 AM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,856 Likes on 1,099 Posts
Is 5 correct?
If you have the stock oil pan, 5 quarts is correct with a filter change; you probably have the wrong dipstick. '57 dipstick shown below.
Old 06-12-2010, 12:00 PM
arizonapete
OK ~ Thanks John ~ mine does not look like that. Can you tell me the length from the flange/stop to the full mark?
Old 06-12-2010, 12:35 PM
67L36Driver
67L36Driver's Avatar
Also depends on if you have the correct dipstick tube. At least the one that goes with that particular stick.
Old 06-12-2010, 12:39 PM
arizonapete
Guess I need the measurements of both in order to determine if the problem is the dipstick, or the tube, or the oil pan...
Any source for those measurements?
Old 06-12-2010, 01:12 PM
67L36Driver
Why not use one of those compact tubing cutters to trim the tube back untill you get it to read "full".
Old 06-12-2010, 01:52 PM
finleyeagle
finleyeagle's Avatar
Default 57 oil capacity
Hi Guy's
I hate to get in the middle of this but my 57 270 car with the correct original oil pan used 6 qts of oil. I do not know if it is listed that way anywhere and I no longer have my car, only 56's currently. Just my 2 cents worth.
Later Mike
Old 06-12-2010, 02:27 PM
JohnZ
JohnZ's Avatar
The late '56-all '57 dipstick was P/N 3722959 (which wasn't on the stick, and Corvette was the ONLY application that used it); from the seat to the full mark was 19-31/64", and to the add mark was 20-7/16". Don't have the measurement for the tube.
Old 06-12-2010, 03:35 PM
arizonapete
Hmmm...
The dipstick does measure 19-1/2" to "Full" (close as I can come to 64ths with a tape~ but close enough) And it shows full with 6 quarts.......
Thanks, guys ~ Will keep looking for the tube measurement
Old 06-12-2010, 07:00 PM
1955 copper
1955 copper's Avatar
2015 C1 of Year
Base engine 57 and 58 the same
Old 06-12-2010, 09:17 PM
56Heap
56Heap's Avatar
With the stock canister filter, oil pan, dipstick and tube my 56 takes 6 qts
Old 06-13-2010, 04:26 AM
arizonapete
OK ~ Thanks Heap ~
The asterisk on copper's chart above notes that the listed capacities are "without filter change"...
(and while the measurements are approx. the same, the '57 dipstick is a different part # than the # listed for '58....)
Old 06-13-2010, 10:41 AM
1955 copper
2015 C1 of Year
Your pic is the first design for 55 ,I believe the 57 is different using no arrows
Old 06-13-2010, 01:33 PM
JohnZ
JohnZ's Avatar
Nope. '58-up dipstick was a different length to the markings than the one used on the late '56 and all of '57. Early '56 (1st design, RH dipstick) was yet another dipstick.
Old 06-13-2010, 01:51 PM
1955 copper
2015 C1 of Year
I was thinking the oil pans Basically hold the same amount of oil. What is the lenght of 57 then 58? or is it the oil tube lenght? Thanks
Old 06-13-2010, 02:45 PM
JohnZ
JohnZ's Avatar
Must be the tube length, as the pans are the same; can't find the dimension for the tubes.
Old 06-13-2010, 03:14 PM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
'56 second design tube 7 11/16"
'57-'61 Corvette, '57 pass 8 cyl. 8 21/32" curved
Don't know if this is right/wrong. It came out of '61 P&A book.
To '57 Oil Capacity
Old 06-13-2010, 03:50 PM
1955 copper
2015 C1 of Year
OK ! Here is what I do know, the 55 oil stick is #3717868 first design showing arrows and 55 only I believe .
Tube is #3711729 and is curved and 6 1/4 long and this tube will NOT fit any other Chevy engine because later engines the tube hole is larger .
Because later engines used a oil filter 55 is a odd engine.
Old 06-13-2010, 04:55 PM
MikeM
MikeM's Avatar
Again, according to this '61 P&A book, you're correct on the dipstick. The tube you show #3711729 is for pass car. Corvette tube is #3718612 and is 3/16" shorter than the pass car tube.
Old 06-13-2010, 05:08 PM
1955 copper
2015 C1 of Year
First I NEVER believe a parts book , they keep changing unless you have that year parts book for that year Corvette,each year they supplement the numbers. You see that on e-bay all the time using the newer book saying the part is original number part( that's why it cost more to learn the correct design part) . I know the 55 is 6 1/4 long . By the way 55 car is the same as 55 Corvette like so many other parts.
Quick Reply: '57 Oil Capacity
