Cable lube?
Cable lube?
What type of lube should I use to lube for the speedometer/tach cables?
I don't recall seeing a cable specific lube at the parts stores.
Kable-ease available through most Corvette parts catalogs and many auto parts stores. Do not lube the top 1/3 of the speedo cable end that screws into the speedo. The lube will travel up the cable on its own. You don't want it getting into the gears inside the guage.
