The car is packed 48 states await
#1841
Rear end update
Almost done, more comments from Gary.
Hi Jack
Here I fit the new ( rebuilt) Lone Star standard axles. With a common built posi with the springs and plates you would just pop these in with the snap ring and that's it. I have seen rebuilt diff's with axle endplay over .100"!
The tuned posi requires the axles to be fit most of the time, the last diff I did they fit perfect but just about all tuned posi's will have -0- endplay or you might not even get the snap ring on. So I set them up in the surface grinder and grind off 005-010" from the hardened face and set the end play to 005-008". This varies because the spiders are not a fine machined gear so they might be a little different through 360*.
Going back to the posi tuning, this is important to get right otherwise you will issue with the axle gap in addition to the posi not working correctly.
So here it is, all I have to do is fit the cover, shoot a touch coat of paint and crate it up for you. Tomorrow I am off so I will be at it on Friday and have it on the dock for pick up on Monday, you will have it on Tuesday.
Any questions?
Gary
Hi Jack
Any questions?
Gary
#1842
Rear end update
Hey Jack,
I installed the cover and shot a touch up coat of paint on tonight. Tomorrow I'll come in and crate it up to ship on Monday FedEx.
I will include 2 bottles of posi additive. You will have to pick up 2 bottles of Lucas 85-140 gear oil and you can reuse your old fill plug which you should have there or you can use the new one I installed. Seal the plug with some tape or thread sealant.
You will have to break in the new gears too, I will have paperwork in with the diff to cover the procedure. This is important, you don't want to burn up the new gears.
You should have it on Tuesday.
Thanks Jack, this was an interesting build to say the least.
Gary
Gary
#1843
The Rear End Comes Home
The rear end build is over. I just received the box and now I have to start thinking about the installation of the drive train.
But that can wait for another day.
Here it is , and thanks to Gary Ramadie for creating a work of Art.
Just waiting for the rest of the drive train
Here they are , waiting for me to crawl under the car and install
#1844
Cruise-In III Veteran
Gary DOES VERY GOOD WORK. I, like you, was pleasantly surprised and impressed at the length of detail (expressed in emails with pictures) Gary goes through when he works on diffs, steering boxes and trailing arms AND the almost daily updates as he progresses through a rebuild of these components.
So where to Jack?
You've got to be ready for an "around the world" trip somewhere when she's all back together.
Jim
In God We Trust!
So where to Jack?
Jim
In God We Trust!
#1845
So where to Jack?
Jim
In God We Trust!
So where to Jack?
Jim
In God We Trust!
Hi Jim , keep this quiet until I make a formal announcement , but I will see you at Carlisle for your 50th woopy do...is that why the motor is in the air .....or did you drive too fast....
Jack
#1846
Hi Jack,
A soft thumping sound that never went away. Was experiencing this for 4 years. Didn't seem to affect driveability, power and idle quality. Just got more noticeable this year. So, out she's come. Look forward to seeing you and others here at Carlisle.
Jim
In God We Trust!
Jim
In God We Trust!
#1847
I got a room at the Inn
Hi Jack,
Jim
In God We Trust!
Jim
In God We Trust!
I have gotten a room at a local run down rooming house, just my style!
Details of trip soon. Leave Maine August 15, heading south to PA, hope to stop by and see old & new friends along the way. I will post route and dates soon.
Jack
Ps I start putting car together this week..
#1848
Rear End and Transmission Installation
Well I celebrated Memorial Day Weekend with a little car work. I now have all the parts ready for installation .
The first thing I have to ask is , Why did I think I could do this ?
Next I had to get the transmission back in . Replaced the throw-out bearing, rear bearing and seal. Never easy...I finally resorted to the push the tail over the cross member, roll the tranny on to my chest, and do a push up with it . It went up and in. No problems but a lot of back and blue marks on my arms and body.
Drive shaft hooked up with new slip yoke
Using a jack, I lifted up the rear with cross member and bolted it to frame
Next the haft shafts...using jacks to lift the TA up to level to install HS
Next up the strut rods and spring later in the week, waiting for parts
#1849
Jack,
Well done!! Your '66 AND you will appreciate all this attention 'cause you have now minimized any surprises on your upcoming trips. Speaking of which I, with the help of a good friend/neighbor Jim Minton, reinstalled my 327 after replacing the main and rod bearings, oil pump and turning/polishing the crankshaft. All is good as she's back in and just got her all hooked up yesterday. Doing the necessary shake down of oil, gas and water leaks. Got her nailed down to a water pump bolt weeping. Only casualty was I shorted a weak battery in this whole process so will be shopping for a new battery. While my motor was out, you guessed it, whileimatits took over and I replaced all the heater, fuel and radiator hoses as well as both belts.
Again glad to hear you're on the homestretch and can see daylight knowing it's not a freight train coming your way.
Jim
In God We Trust!
Jim
In God We Trust!
#1851
New Pipes
Just delivered , new pipes for the car, I will post later what I do to them to reduce cabin heat.
Waiting for new cam adjuster kits to install new strut rods.
Jack
Jack
#1852
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
What do you think the whole project cost you Jack? Are those stainless pipes? :
#1853
About $3,000 including the rear end rebuild . Plus the donated rear end from Ed Johnson . Labor was on me. Some of the cost was for tools and shaft balancing .
Regular pipes, as I had to cut up my welded pipes.
Hrs about 20 only because of no lift and a lot of wire brushing and crawling around. Putting the tranny back was the hard one ,as I am not as strong as I once was......
#1854
Car is almost back together
More photos later, but I got the rear in, spring and wheels on
Started on first try after 4 months on stands
#1855
Rear End
#1856
My rear end is back in the seat again......
My rear End is in the seat once again......The first ride of 2015.
After 6 months of restoration , the car held together for a 20 minute ride to start the break in of the newly rebuilt rear end, transmission and suspension..
I did the removal and installation with the car on jack stands.
I do not recommend this method , but like many of us, I had no choice..,,,,,,,.
I have to go now....time for another 20 minute ride....
If you click on the link you will see the video of my first ride, looks better on computer then Iphone , speakers for sound
#1858
Sounds great Jack. Is that an M22 with straight cut gears? Sounds like it. I don't recall it sounding like that when I drove it, but then again I can't remember what I had for breakfast either.
3K for what you accomplished is about half what it would have cost you if you had it done. And the level of rear end quality is the best Ive seen. Well done, and happy cruising Jack .
Do you like the new ratio better than the other one? :
#1859
I had forgotten how nice the 3:36 is, perfectly matched with the wide ratio Muncie. Need to have rear end aligned before I get on it
Jack
#1860
Alignment specs ?
Hi , I am almost ready to give an update on the rear suspension project.
Tomorrow I bring in the car for alignment. I have all the factory specs, but I know that the front with radial tires is set a little differently then factory.
My car is completely stock front suspension with original style A arms.
1966 L-79 with stock power steering setup. Tires are 215 R 70 15
Should I try to get for the following specs based on radial tires and my hi speed (70-90 mph) for long periods of driving on my
trips...
Front
Toe Factory ?
Caster As much as possible 2 + ? if A arm will allow
Camber Factory ?
Rear
Camber 0 or fraction less
Toe Factory
Jack
trips...
Front
Toe Factory ?
Camber Factory ?
Rear
Toe Factory
Jack
