C2 Vintage Air- Spal fan power connections
I have Vintage Air and Spal fan on my '63. As suggested in previous threads, I rewired my a/c and Spal fan power wires from Vintages recommended battery connection, over to the horn relay.
Instead of a positive charging situation, it now takes a deep negative dive when the a/c and spal fan go on.
When not using the a/c system,the car charges fine. Needless to say,it's losing badly with the A/C-Spal fan on.To the point of draining the battery.
I am running the Powermaster 65 amp alternator.
Hooking it up the way Vintage Air suggested causes the needle to go about 25% + past 0 on the gauge face. Is this even an issue? I have returned the hookup to Vintage Airs suggested connection.
Any ideas?
Any ideas?
I have a 100amp alternator and hooked up the electric fan and A/C to a 50amp circuit breaker I mounted near the alternator. I have 30amp fuses on the fan and a/c lines. The power now comes directly off the alternator to the breaker. That supplies only the A/C and Fan. My battery gauge now reads correctly.
I am wondering if a 140 amp alternator will cure the issue without any wiring changes?
Yep, run a second red wire from the alternator to the 50amp circuit breaker. I did this because I didn't want to change the original harness or send too much juice through the harness than intended.
St. Jude Donor '07
my .02... a higher potential amperage should have a larger wire, probably a 10 gauge all the way back to the battery.
if you are going to use a bus bar arrangement (which is what the horn relay is acting as), then run a dedicated additional wire from the alternator to the bus bar and draw your a/c stuff from that.
Bill
Bill
I dropped my unit by the local alternator shop. They are upping it to the 140 amp range. I am considering a larger gauge alt wire also. Some say you should and some say you don't need it. ??
Run an additional 10 ga wire between the alt and the horn relay, whether you have a 65 or a 140 amp alternator. The 10 ga harness wire on the alt gets too hot otherwise. After that, if the battery meter problem persists, clean the battery meter connections in the bulkhead plug.
All bulkhead and gauge connections are fresh and clean.
St. Jude Donor '07
fwiw, doing the math, 2 #10s is a larger conductor than a single #8,
#8 0.128x3.14=0.40 conductive surface
#10 0.102x3.14=0.32 x2=0.64 total conductive surface
saves pulling the old wire out...
Bill
yes, i think he is saying to run an additional 10 gauge along with the orig wire. the horn relay is acting as a bas bar, splitting the current off to other places. i would go so far as to run an additional #10 parallel to the original, all the way back to the battery.
Bill
Bill
These thing are more complex than they seem. I have only a modest idea of what the splice is and what it does.
Mike, we seem to be kind of in the same boat here. I do have a NOS under hood wiring harness I purchased some time ago as I was going to have my mechanic re-wire the car before I had him install the Vintage Air. I might try and take a pic of it and maybe it will show the splice ??? Or just throw more confusion on the table? What do you think?
St. Jude Donor '07
toss it on the table, it's the only way to get an answer (or answers... )
Bill
Trying to REPLACE the line in the factory harness with a larger wire may have unintended consequences - no disaster, but where the regulator senses the load on the harness is important. I know the added wire works because I did it to my car 10 years ago.
