Reverse Lock Out Question
On a 67 Vette the reverse lock out lever is pulled up to enable the shifter to select reverse gear.
Once in reverse Do you have to pull the lever again while returning the shifter from reverse to neutral postition?
Received 1,856 Likes
Here's what's at the bottom of the lever that performs the lockout function; when you pull up on the T-handle, the rod moves up out of the way and allows the lever to move across the gate into the reverse position.
Lockout rod won't drop all the way in
What a GREAT picture John! It confirms a problem that I'm having right now.
I'm putting my shifter back together, and I cannot get the reverse lockout rod to drop far enough down into the shifter shaft to screw the ball back on.
I figured that the rod must exit the bottom of the shifter. For some reason it won't do it; I've tried going through the shift pattern many times over with no luck.
Any ideas before I crawl under to check things out?
Received 1,843 Likes
If the pin is not dropping through the shifter to block reverse, address that problem before you do anything else.
My fathers 64 recently had the reverse lock out rod get stuck in place. I had to take the entire shifter out to fix it. Now, for some reason the hole in this particular shifter was different than on my 65 and my fathers 66 and the rods from those cars would not work on the 64. I ordered a new rod and it would not work either. So, i ground the tip of the new rod down until it fit the hole in the shifter and it works great now. Perhaps you have the same problem and just need to provide a little more clearance.
Thanks guys, I'll let you know how it goes.
Merry Christmas!
Joe
Merry Christmas!
Joe
Thanks! John
You might get a faster answer on the specifics of the C4 shifter if you post the question in the C4 forum (unless one of our C1/C2 regulars also has a manual C4).
