intake manifold casting # 3844468??
Old 09-06-2010, 03:08 PM
64con
64con's Avatar
Default intake manifold casting # 3844468??
I'm looking at buying an original cast iron intake for my 1964 327 300hp roadster. I put in a ad locally and had people send me casting numbers so I could get the correct intake. I got a reply with the 3844468 # .......I can see that the first 3 numbers are correct but I can't find the last 3 numbers anywhere online..... 457 as the last three indicates a 250hp application.......459 is for a 300hp(which is what I'm looking for) the 461 is an aluminium 350hp application........what's up with this 3844468 casting number.
Warren
Old 09-06-2010, 03:39 PM
devildog
Support Corvetteforum!
devildog's Avatar
Location: fighter pilots make movies, bomber pilots make history
Warren,
I do not know what that is. Here is good quick guide to Corvette numbers
http://www.corvette-world.com/corvet...ifications.php
Joe
Old 09-06-2010, 03:45 PM
RoadKing96
RoadKing96's Avatar
Location: Holly Springs, Nort Cackalacky / Jupiter, Florida
Warren
Warren,
The part # you need for the L75 is either 3852569 (casting # 3799349) if it's an early '64.
Or
You need part # 3844457 (casting # 3844457) for later model '64. Same as used on the 250hp base model.
RK
Old 09-06-2010, 03:46 PM
64con
64con's Avatar
Originally Posted by devildog
Warren,
Joe
been there done that......thanks though
Old 09-06-2010, 04:45 PM
64con
64con's Avatar
Originally Posted by RoadKing96
Warren,
Or
RK
[/I]
When I look at corvetteworld.com they state that the 3844457 is for the 250hp and the 384459 is for the 300hp the 3799349 is the early 300hp.....are the 457 and the 459 identical intakes?
Old 09-06-2010, 05:06 PM
5thvet
5thvet's Avatar
I show 3844457 250HP
3799349 early 300 HP
3844459 later 300HP
Don
Old 09-06-2010, 05:09 PM
ragtopman
ragtopman's Avatar
St. Jude Donor '10-'11
...and if you need, I will look in my Alan Colvin books for you.
Old 09-06-2010, 05:43 PM
RoadKing96
RoadKing96's Avatar
[/I]
I see that corvetteworld has that for the '64 and '65.
I am getting my information from the "Corvette Parts Interchange Manual" for 1963-1967 by Paul A. Herd.
Not sure which of these two are correct, but I can only assume that one of them has that last digit incorrect. Those with the 'actual' 300hp intake will chime in. Wonder if it might be where the casting numbers are being confused with the 7 and 9? I know some actual castings I've viewed are not necessarily the best.
RK
Note: I am not a paid spokesperson, nor will I realize any payday for mentioning Paul's book. It's just plain good.....
Old 09-06-2010, 05:57 PM
64con
64con's Avatar
Not sure which of these two are correct, but I can only assume that one of them has that last digit incorrect. I'm thinking Paul's book might be my choice as the book has been spot on for me so far......
RK
Fair enough.......I went to numerous web sites and found both 457 and 459 references.....I do appreciateed the replies.........thanks again
Warren
Old 09-06-2010, 05:59 PM
64con
64con's Avatar
If you could look that would be wonderful.......I did see a picture with the 3844468 # stamped on the intake manifold so it's not type-O
Old 09-06-2010, 06:06 PM
Jalopy31
Jalopy31's Avatar
There was a discussion on the NCRS forum recently regarding the various intakes for '64 327/300 cars:
http://www.ncrs.org/forums/showthrea...ntake&uid=1400
Hope this helps.
Todd
Old 09-06-2010, 06:16 PM
RoadKing96
RoadKing96's Avatar
Warren
Warren,
Just looked it up in the NCRS latest judging manual for the '64 and the number they have is 3844459.
So it looks like I have found my first glitch with Paul's document and will make a mod to it based on your thread.
Good luck,
RK
Old 09-06-2010, 06:33 PM
brownacc
brownacc's Avatar
Default RoadKing96
Warren,
Good luck,
RK
Roadking , I sent you a PM about the engine block but for some reason I dont think my PM works on this site ?
Email me with the info if you will.
Old 09-07-2010, 12:21 AM
oldskydog
oldskydog's Avatar
Are you sure the 3844468 is cast iron? If it's aluminum it might be 3844463 where the 3 looks like an 8 and that would be a 63-64 400hp 409 intake.
Old 09-12-2010, 12:19 PM
64con
64con's Avatar
It's cast iron.I saw a picture of the intake and the 8 was well defined. Thanks for the reply. I'm not interested in installing an intake that's not correct for my car BUT I'm still curious about the intake since I went to alot of chevy web sites and could not find the casting number at any of the sites
Old 07-24-2012, 10:22 PM
krummthedog
1st Gear
krummthedog's Avatar
i have that intake in my possession 3844468 its a big block aluminum intake for a carter carburetor (i don't know much about it but do have pictures if anyone wants to see it)
Last edited by krummthedog; 07-24-2012 at 10:24 PM. Reason: wasn't finished typing
Old 06-02-2016, 01:21 PM
Jerry Nealon
1st Gear
Jerry Nealon's Avatar
Default Manifold
Warren
I have a manifold with the number 3844457, is that what you are looking for? Jerry
Old 06-02-2016, 05:20 PM
tuxnharley
tuxnharley's Avatar
Received 1,939 Likes on 1,185 Posts
Colvin's book does not list that manifold as being a Corvette application.
EDIT - Oops, got duped into responding to a 4 year old thread! I really wish the thread titles could include the original first posting date!
To intake manifold casting # 3844468??
Quick Reply: intake manifold casting # 3844468??
