Distributor lube
Received 6,928 Likes
2015 C2 of Year Finalist
dielectric grease. wrong part lube. but John corrected it
Received 1,856 Likes
I stuff the cavity full of strips of gauze bandage and then soak the gauze with motor oil; that's the only lubrication the upper bushing will ever see - only the lower bushing sees engine oil. Use motor oil on the felt washer below the breaker plate too - that's the only lubrication the breaker plate pivot will ever see.
1 Post
regards,xiaoman
Received 3,766 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Lars may have a good solution for the ideal lubricant in this cavity.
Lars, oh Lars, are you here?
Tom Parsons
Tom Parsons
I was in contact with Lars a little while back and he recommends to fill the cavity with wheel bearing grease and make sure when you push the plastic seal down on top the grease oozes through the lube hole inside the bushing.
