best carb set up for 327/365hp 65' c2?
Navigator
i have a driver thata has a edel-weber 8867
carb, i think 600 cfm?
carb percolates, i was looking for a phenolic spacer
but may not have room at the stock hood.
also was told yhis is not a good performance carb.
any reccomendations pn what the best performance carb setup is for my driver?
appreciate any help
thx
appreciate any help
thx
Received 6,943 Likes
2015 C2 of Year Finalist
whats wrong the stock Holley
I am running a Holley 600 Double pumper with 1/2 inch phenolic spacer with BB air cleaner on my 365hp intake. Fits under stock 63 hood.
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
You're lucky these guys talked to you. Fill in your personal data and learn how to proof read your posts before you submit. On my 66 400hp small block I used a Holley double pump 750 or 80, and it was perrrrrrrfect.
I agree the personal information is helpful, but lets be nice about it.
I see that the Holley 2818 sells for about $600 and up.
Isn't it pretty much the same Holley 600 cfm that sells new for about $250?
Don't have a clue just curious.
If you have a stock manifold, I would try the spacer and maybe go with a shorter air filter or drop air cleaner base. I have the Edelbrock RPM Air Gap manifold so no problem with peculation. Also I am running the Holley 770 street avenger.
You are running a 383 stroker aren't you?
Navigator
thanks for all the reply's...
thinking about the holly 2818, but is it that
much better then what i have now (edelbrach-weber 8867)?
most likely will still need the phenolic spacer as well.
i filled some of personal info... gook the familly to a
dodger game today so i was filling out my registration in a hurry.
thx George
thx George
Last edited by cyc-rider; 09-18-2010 at 03:08 AM. Reason: put in wrong carb number
The Holley 2818 is a very good carb if you want to have that original #s matching Holley carb look. The Holley will need the phenolic spacer less since the fuel bowl are not as directly exposed to the heat from the intake manifold.
I hope this helps Henry @ olescarb
Navigator
olescarb,
the carb has weber & 8867 casted in & a Edelbroch sticker in the front (sticker looks like it belongs there since the carb is indented for that exact size sticker.
after thinking about it for now ill keep the carb & just find a phenolic spacer until im ready to beef up or replace the eng. sure would like 450+hp someday.
Tell me you didn't know what I meant! 750 or (7)80, I can't recall which. And I am nice, and people like me, they really really like me......
