New FI Unit has arrived
My Arizona Speed FI unit has arrived. What a beautiful piece of work. It really does look old school, Can't wait to get this on. Just waiting for the aluminum vortec heads I ordered to be built.
Bob
Bob
Beautiful piece.
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
Can I ask a price range or a website for same. Is it 'bank job' necessary high$$$?
Yeah it is not cheap. Here is the website. http://azspeed-marine.com/
The price quoted is for the base package with the standard GM HEI Dist. I had them upgrade to the MSD 8572 Corvette tach drive distributor. I upgraded from the narrow band o2 sensor to the wideband o2 sensor. I purchased the software package so I can tune it myself and I upgraded to include a knock sensor.
Bob
Bob
St. Jude Donor '07
Bob
Bob
whose electronics does it use? mine is Accel
Bill
Charles
Charles
Correct about the MEFI4 ECM system. The ignition control module is stock GM. There is a seperate box for the wide band sensor. There is also one of those ugly external HEI coils. So I'll have to hide the ECM, the control module, the ugly coil and the wide band sensor module. I had a custom harness made with 4 feet of wiring between the unit and all the boxes so I should have a few options.
Bob
Bob
Received 1,762 Likes
St. Jude Donor '07
Bob
Bob
Bill
I still have some room on the firewall under the heater box I may be able to put the ECM and the wide band sensor box there. Of course you would have to remove the battery if you ever need to access it. The HEI coil and the ICM I am going to mount somewhere behind the ignition shielding so you won't be able to see it. It's too bad they don't make an HEI coil that looks like a regular coil.........
The GM Ram Jet 350's have the ICM built into the distributor. Wonder why AZ Speed is not using one of these? Is your distributor a GM part?
Charles
Charles
Nope, as per above, I upgraded to the MSD 8572 small cap corvette tach drive distributor so I could retain my stock tach and use my stock chrome.
St. Jude Donor '07
Bill
