65 Shift Boot Replacement
The rubber shift boot on my 65 is rotting away and I need to replace. I have a muncie 4 speed with the reverse lock out. How big a job is that? Any suggestions or instructions would be appreciated
If memory serves, you have to remove the center console.
This requires:
1) remove the shift ****
2) remove left and right radio trim panels
3) remove all center console screws
4) put gear shift in 4th gear
5) carefully remove console
On my 65, I couldn't get the center console off unless the shifter was in 4th and the **** was removed.
Once the console is off the shift boot should come off.
Jeff
This requires:
Jeff
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Only thing I might add is remove the reverse lock out t-handle.
Its a pretty easy job.
Cruise-In III Veteran
teasipper,
Yes, you must remove...can't just stretch the new boot over it. There's a metal reinforcement plate with a # of screws which the boot screws to. Your boot has holes punched to conform to this plate. Must unscrew all in order to secure the new.
Pretty straightforward.
Regards,
Jim
In God We Trust!
Regards,
Jim
In God We Trust!
Former Vendor
