Need muncie 4 speed ID info.
I've got a '72 LT-1 that I've just removed the transmission from. It's a Muncie 4 speed. Can someone help me ID what year transmission it is? R/S tail shaft #3978764, R/s case 7P09, R/S case # 3885010, L/S on shifter housing #3952648, and L/S #7S107786. Any help would be greatly appreciated. I'm thinking this maybe a 1967 transmission.
I know Cast # 3885010 = 65-67
I think #7S107786 is vin# from January 67.
#7P09 may mean built Jan. '67
I don't know what #3978764 or #3952648 mean. Is it an M20, M21, or M22?
Thanks;
Steve
Thanks;
Steve
Received 1,857 Likes
Thanks;
Steve
Thanks;
Steve
The main case is from September '06, originally installed in a '67 Corvette built January 11, 1967.
That tailhousing was used from '71-'74.
The side cover was used from '70-'74.
If it has the original input shaft, 2 grooves is an M20, and one is an M21.
Mike67nv, 78 Silver 78;
Thanks for the link. I was there this morning. That's where I got the casting number as a 65-67. The only real question I had was I didn't understand what they meant by rings to determine if it's an M20-21-22.
JohnZ thanks for identifying the other numbers. One groove on the shaft.
So I guess I've got a mix & match LT-1. That's OK. It's still a very nice car.
Thanks to everyone for their input. Now I've got to buy a new clutch package.
Here are a couple of other web sites I've found helpful:
http://www3.sympatico.ca/atkinsom/history.html
http://www.chevcarclubvic.org.au/tec...tification.htm
