Quick question - voltage regulator wiring
I just replaced my alternator with a new 3 wire, 100 amp unit. Today I took her for a test drive and when I returned my battery (optima red top) was totally drained. Battery just checked out fine about two weeks ago (leading me to replace the alternator).
On a side note, I'm punching myself in the ***** while I'm writing this. Getting tired of sudden electrical weirdness.
The alternator has two connections - "F" and "the other one". Since my harness is custom I don't have the "only fits one way" connector.
I took a multimeter and checked the resistance of each connector to ground. One was 4.6 ohms and the other didn't go to ground.
I believe the one that gave a reading (apparently anything over 2.5 or so is fine) is "F".
I also installed a solid state external regulator. Wiring going to it is to spec.
I may have had them hooked up backwards before. Does this sound (punch) right? (punch).
Disconnect the harness from the alternator and the regulator. Check these with an ohmmeter or self powered test light: the F terminal on the alternator plug should have conductivity to the lefthand most terminal on the regulator plug. "The other one" (the R terminal) on the alternator plug should have conductivity to the terminal next to the lefthandmost terminal on the regulator plug.
I read that nothing bad will happen if you reverse these wires - just your battery won't charge. I've got it on a charger tonight and I'm going to run it tomorrow and see what happens.
My voltmeter (ammeter is in a box) reads 14+V when running - but apparently it wasn't going to the battery although I can't imagine how it wouldn't....
Looks like I managed to kill my Red Top Optima (ouch). Won't take a charge - can't even work up enough amperage to engage starter solenoid.
Although, I think I do have the wiring right. But between my old alternator and the possible wire reversing my battery has had it.
Oh, well. What's another $178?
Have you seen the threads on how to charge a completely discharged optima? You kind of have to indirectly charge it with some of the new trickle charges. Look on YouTube for the video from Optima. You may be able to save it.
Don
Don
Here's the link...
http://www.youtube.com/watch?v=Slqd7...eature=related
So now I'm stumped.
Is there any way a new alternator could have killed my starter? I have one of those mini high torque starters. It just clicks like it's not getting enough power. Checked my maxi fuse (Painless wiring system) and it's fine.
Never had any electrical issues before - only thing different is new alternator. What the hell?
Research a little at Madelectrical.com, or call them if you can get them, as I recall the hot power lead from the alt needs to run direct to the amp meter (I suggest shunting, jumper across the back) and then your electrical system will get power the way it used to.
Here's what I don't understand. I wired it exactly like my previous alternator. The only difference is that my new alt doesn't have a ground post - it grounds through the case. I checked it with a multi-meter and it's grounded.
The other weird thing is that I started it up about 4X with this new configuration and it ran/started fine. All of a sudden, after a test run, I shut it down and when I went to restart - it was dead.
All I did was swap out the alternator. Nothing else changed. Never had a charging problem or starting problem before.
Once I get the battery back in, I'm going to test the voltage at the starter when cranking. I'll also check to make sure the starter isn't shorted.
Another strange issue with this is that the system intermittently is totally dead when turning the key - no voltage at the gauges, no clicking, nothing.
A few minutes later, the volt gauge is back and the starter clicks like a dead battery.
Jeez. I just needed a new alternator. What a hassle.
Here's something I found in the manual for the wiring system:
Apparently, installing a higher voltage alternator requires modified wiring - although it seems that the external regulator has disappeared. I'm guessing that wiring is the same - just eliminated from this drawing (shows a later model GM alternator with internal regulation).
Now I'm really confused. I'll call painless to check.
IF USING AN ALTERNATOR WITH AN OUTPUT LARGER THAN 65 AMPS, YOU WILL ALSO NEED
TO USE THE RED 10 GAUGE WIRE #960 AND THE RED 8 GAUGE WIRE INCLUDED IN THE BOX. THE WIRE END WITH THE RING TERMINAL AND RUBBER BOOT WILL CONNECT TO THE ALTERNATOR OUTPUT LUG WITH #915. ROUTE THE OTHER END TO THE MAXI FUSE TERMINAL WITH WIRE #916. CUT THE WIRE AND CRIMP ON A RING TERMINAL. NOW INSTALL A RING TERMINAL ON THE REMAINING RED 8 GAUGE WIRE AND ATTACH IT TO THE STARTER SIDE TERMINAL OF THE MAXI FUSE. CUT THE 8 GAUGE RED WIRE TO LENGTH, CRIMP ON A RING TERMINAL AND ATTACH IT TO THE MAIN SOLENOID LUG WITH THE POSITIVE BATTERY CABLE. SEE FIGURE 7-2B.
"Another strange issue with this is that the system intermittently is totally dead when turning the key - no voltage at the gauges, no clicking, nothing."
Have you checked the firewall side wire connector with the infamous big red wire?
Don
Don
Received 1,123 Likes
You might have two things going on. One is a charging problem and the other might be a connection problem at the firewall.
You stated that there was no ground terminal on the alternator. I am not that fimiliar with mid years but doesn't the ground for the regulator connect to the housing of the alternator?
Use this paper I wrote to understand and check your system.
Can you post a picture of the alternator installed?
Joe
http://temp.corvetteforum.net/classi...ternator.shtml
Joe
Photos coming.
Thank you all for your help - I'm still digging for answers with various mfg's - Painless, TuffStuff (alternator), and powermaster (starter).
Mystery solved. Thank you all for your suggestions- very helpful as usual.
Turns out it was a combination of things - loose engine ground, deteriorated (+) battery cable (only lasted 2 years!). Plus, I found out that when you go to a high power alternator, Painless requires an extra 8 gauge wire from the positive terminal on the alt to the maxi-fuse. This prevents the main wire from burning up.
I also increased my battery cables to 4 gauge and installed a solid state regulator.
