C1 Starter question - Tom Parsons?
Friend with a 62 wants to know if an engine mounted (staggered bolt, for the 168 tooth flywheel) starter can be made to be used with the OEM manual trans bell housing (with bell housing mounted starter mount).
What would need to be modified (if this is even possible)? I am sure the bell housing could be modified, but by how much?
Understand that the correct bell housing mounted starter nose could be swapped onto the starter, but he wanted to know what would prevent the usage of the engine mounted starter nose.
Plasticman
Plasticman
St. Jude Donor '07
Tom
just to refresh your memory, i found this old post...
http://www.chevytalk.org/fusionbb/sh...hp?tid/179697/
Bill
Bill
Plasticman
Plasticman
I am using a 1967 Corvette starter on my 61 with the
61 bell housing (with bell housing mount for starter). I have
a 74 small block with the two engine bolt holes (350).
There is no problem with the bell housing, but had to use
a shim between the starter and engine block (.050). Without
the shim, the starter gear does not dis-engage very well.
Hope this helps.
Ray
Received 3,769 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Plasticman
Plasticman
That's it, that's all.
A starter shim SHOULD NOT be needed. You're matching the appropriate starter with the flywheel, NOT matching the starter with the bell housing.
Tom Parsons
Wish I woulda known...
With a later block, that has the BLOCK MOUNT starter holes, AND, if you're using a 168 teeth flywheel (ANY year model 168 teeth flywheel, the starter ring gears are ALL the same), you will need a starter with a CAST IRON nose and staggered bolt pattern. GENERALLY, this combination, and any 55-62 open bottom bell housing is perfectly compatable. On ultra rare ocassions, it has been necessary to some VERY minor clearancing, with a die grinder and a small grinding stone, around the starter opening on the bell housing. But it is usually a perfect fit.
Tom Parsons
Tom Parsons
