*General Grand Sport Topic*
#622
63 Grand Sport Emblem
Guys, does anyone know where I can get hold of a rear deck emblem of the Corvette 'script' and the Grand Sport 'Bar'?? any help would be much appreciated.There was a post July 2010 but that part no is obsolete!!
#623
Received 6,528 Likes
C2 of Year Finalist (track prepared) 2019
It's not a perfect solution, but it's a good "10 footer" solution.
Jim
#624
Mongoose sales the "Grand Sport" overlay for the stock 63 rear deck emblem.
#625
Grand Sport Rear Deck Emblem
I've been wondering where to get one myself.
I figured I would wait until my project was all done and that would be the last piece to put on. By that time, there will be no one alive who remembers what a Grand Sport is.
#626
GS Rear Deck Emblem!
One way to make the rear deck emblem is to very carefully use a Dremel to trim a '63 Sting Ray rear deck emblem to harvest just the word "Corvette". Then, below this mount the "Grand Sport" emblem from a '96 GS Vette.
Jim
Jim
#627
Grand Sport Emblem
So long as you can still remember ......what a sweet moment that will be though!
#629
Ed
#630
Jim, thanks, for your reply! I have been going back through some of the forum history! At the risk of sounding like the president of the Jim Lockwood appreciation society, you are a top man! You seem to be active in many of the GS threads and replys. Very knowlegeable ......very patient and helpful in the extreme ......long may you continue! Sincerest regards Martyn
These are not easy cars to build, requiring a fair amount of innovation. There is no sense in everyone having to re-invent the wheel when good fabrication solutions are available if you just ask. I'm happy to share my experiences, for whatever they are worth.
Jim
#631
96 GS Emblem
Ed, thanks for that. I did email Mongoose with that info, so will see if that generates a response. Will keep you posted. Again thanks and regards!
#632
Rear Brake Ducts
Well <blush>, thank you. I've had more fun with our two Grand Sports than with any other Corvette I've owned. I can't help spreading the enthusiasm I have for the cars.
Jim
Jim
#633
Like I say Jim, you are a top man! There was one other mystery concerning the rear brake cooling arrangement and rear fender top mounted scoops that you will probably know the answer to. I have tried to see how this worked back in the day on the original cars, without much luck. It seems to me that rather than convoluted tubing routed to the back of the rotors (like on the front) there was a rectangular section fabrication, leading down from a rectangular aperture, (under the scoop cowl), fixed to to the inner wheel arch wall and just terminating in the general vicinity of the rear hubs. Am I correct in this assumption? and if so, how efficient would this have been? As ever, very grateful for any insight.
I have a picture of the ducting I can post, but I'm on the road at the moment and my picture file is at home. Remind me in a week or so about this ducting and I'll upload a picture of the ducting on GS #003.
As for the efficiency of the rear brake ducts, well, I'd frame the question in terms of how necessary they really are.
Think about it like this: About 70% of the braking is done by the front brakes, 30% done by the rear.
The Grand Sports weighed around 2100 lbs when fully developed. Its safe to assume that if the brakes are well balanced for the amount of weight transfer, then at maximum braking, 30% of the vehicle weight is being slowed by the rear brakes..... that's only 600 lbs. A pretty much trivial amount of weight.
I'd submit, but can't prove, that you wouldn't need cooling for brakes which have no more responsibility than that.
Are you planning to attempt duplicating the GS rear brake ducting?
Jim
#634
#635
Rear Brakes.
That is exactly how the rear brake cooling is configured. By whatever means you determined that, congratulations; that's good detective work.
Jim
Jim
I'll give you reminder in a week or so if I haven't heard before then, if that's ok! I think my body must have been an early D&D because it has the 'bump' at the side of the rear deck screen to which Ken referred in his post. Regards Martyn
#636
'Bump'
I think you will find that only the early D&D cars had the small bump added behind the rear wheelhouse that the air ducting passed thru. It can be seen from inside the car. I know the MAI and Mongoose versions do not have this little addition. My 049 D&D does have the bump. Air flow was in the brake scoop a sharp rh or lh turn towards the center of car then another 90 degree turn down . At the bottom of the ductwork a simple 90 degree bend aimed to the back of rear disc's . ------ Ken
#637
Thanks Jim, my turn to blush. I am planning to duplicate the ducting and would really like to see your photo ref when convenient!
Also, if I'm not being too nosy, what serial number is your D&D?
Jim
#638
Grand Sport
Here's the thing, curiously it doesn't actually have a D&D prefix to the VIN. Because it was originally registered in Alaska it has an AK number. I believe D&D were the only one to reproduce the 'bump' faithfully, unless there were other manufacturers out there which have subsequently ceased trading, I don't know. As regards photos I have some 'before' ones on a file which I'll post when I can get it back! Marty
#639
There may be some hidden numbers I can help you find.
Jim
#640
Now I'm intrigued! If there were any numbers they have been super ceded by the AK one. Do you know anything of it's history?
Marty
