56 frame vin number...
hi guys,
happy holidays....
i have to locate/confirm teh vin number on my 56. i have the body on teh frame, and teh engine is in teh car, along with the steering column... there is no interior, so i have easy access to all teh new body mount bolts.... whats teh easiest way to see the vin number on teh top of teh left frame rail, for conformation? anybody have a trick or jacking procedure so it can be confirmed with teh least amount of disassembly?
thanks for any and all ideas,,
john
happy holidays....
john
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
Here's a picture of my '56 stamping. It was stamped twice, almost dead center of the cross member. If you look close you can see the shadow. It was on the out board side of the frame rail. I wish I could tell you the best way to see it without lifting the entire body. Good luck.
I've helped a friend see their 62 frame stamping, using a mirror to look between the body and the frame.
The stamping on a 62 at least is on the frame rail approximately where your left hip pocket would be as you sit in the driver's seat.
Assuming a 56 has it in the same location, you'll need to clean the dirt off the frame in order to see anything.
thanks for teh replies, so far... i know where it is "supposed" to be, but i haven't seen it for many years,, teh frame is sandblasted & repainted, so rust isn't a problem..
i'm thinking of unbolting teh steering box from teh frame, and supporting teh column from a 2x4 across teh fenders, and removing teh radiator and unbolting the saddle, i should be able to lift the body enough to see the number, hopefully without any body cracks!!
again, if anyone has a different idea, i'd love to hear it,,,
thanks,
john
thanks,
john
If you loosen up the body mounts (all of them) you can place a 2x4 under the floor board next to the rocker panel and raise it up with a floor jack. It won't hurt a thing and you will be able to see the numbers. You only need to go up a couple of inches.
thats what i was thinking,,, i put an ecklers front end on it a while ago (cowl fwd), and i don't want to stress it to teh point of cracking seams...the steering column has to be disconnected also, correct?? how about the master cylinder line, clutch and accelerator linkage?
i was going to put long bolts and nuts thru some body mounts to help keep everything lined up, but allow the body to raise...
The steering column will be an issue IF you raise it very high. At least you have a big opening in the cowl, compared to 53-55.
The brake line should be ok with just a two inch lift. You can always disconnect and bleed again. It sounded like the car was a project and not fully operational??
yep, i had it for quite a while and decided to get done... i want to confirm teh vin and frame numbers,,, i guess i should have taken a picture/rubbing of teh frame number before i set teh body back on it to fit teh front end...live and learn.....
Received 3,771 Likes
2015 C1 of the Year Finalist
hi guys,
happy holidays....
john
happy holidays....
john
Tom Parsons
one hand is faster than teh other, or teh keyboard is worn,,, either way,it doesn't much matter to me, as long as someone gets the message....
So by analyzing your typing patterns, I would predict that your quarter mile times would improve with right hand drive vehicle when drag racing with a manual shifter!
Just kidding - please don't take offense.
I was able to see teh numbers on teh frome of my '54 with a mirror and a mag light, no jacking necessary. I just needed to learn to read upside down and backards while laying on my back.
All teh best,
RG
All teh best,
RG
thanks!!!! i'll try that 1st and work up to jacking up teh body...
