Dipstick Length??
Old 12-26-2010, 06:38 PM
Uncle Ralphy
Uncle Ralphy's Avatar
Default Dipstick Length??
What is the correct length for a 1962 oil dipstick??
Old 12-26-2010, 06:46 PM
62Jeff
Support Corvetteforum!
62Jeff's Avatar
Post 9 of this thread might be what you are seeking
http://forums.corvetteforum.com/c1-a...ck-1960-a.html
Old 12-26-2010, 06:47 PM
Stewart Allison
Stewart Allison's Avatar
My misses just told me 12 " is a good length Stewy
Old 12-26-2010, 06:49 PM
62Jeff
62Jeff's Avatar
Don't you guys use metric? So she's OK with 12 mm?
Old 12-26-2010, 06:54 PM
Stewart Allison
Yes that's on a hot day Stewy
Old 12-26-2010, 07:02 PM
StingU2
StingU2's Avatar
That's when it's under a magnifying glass.
Old 12-26-2010, 07:03 PM
62Jeff
62Jeff's Avatar
The dipstick in my 62 was purchased from Chevrolet in 1982 as a "correct" dipstick. I have no idea if it is.
Mine measures 21.5" from the tip of the dipstick to the part that mates to the top of the tube.
The "FULL" line is 2 1/16" from the tip of the dipstick.
Old 12-26-2010, 07:07 PM
Mark_Milner
Mark_Milner's Avatar
Remember that the dipstick AND TUBE have to both match. Simply buying the correct dipstick and using an existing unknown tube can give you false level readings.
Make sure you buy BOTH as a set when getting them.
Old 12-26-2010, 08:29 PM
Kensmith
Kensmith's Avatar
If you know the correct oil capacity with filter and you have the correct oil pan and filter, drain the oil, put a new filter on with oil and fill the proper amount into the pan (5 or 6 quarts or whatever the pan should hold). Then after running the motor and letting it settle it will show where the oil level should be on your dipstick. You can either find the correct dipstick or mark the one you have or check the tube for correct length. Other than that, there is no sure way as I have not seen any exact replacements that will guarantee they are correct. I had to do this for my 383 stroker motor as the pan and dipstick are aftermarket and who knows what the correct dipstick and tube are?
Old 12-27-2010, 12:09 AM
kskid
kskid's Avatar
My corvette parts book from 1975 lists a 62 from place where it sets on tube as
19 3/16 inches to the FULL mark
20 inches to the ADD mark
Old 12-27-2010, 12:34 AM
62Jeff
62Jeff's Avatar
19 3/16 inches to the FULL mark...
That's within 1/4" of how the FULL on mine measures out (at 19 7/16"). Sounds like mine is probably correct given the margin of error in trying to measure where the tube mates to the dipstick.
Old 12-27-2010, 12:37 AM
Mark_Milner
Again, it is very important to know if you have the CORRECT MATCHING tube, as the tubes vary in length also.
Old 12-29-2010, 02:02 AM
Uncle Ralphy
Next question then is: What is the correct length of the dipstick tube from block to top end?
Old 12-29-2010, 02:17 AM
62Jeff
62Jeff's Avatar
I'll measure my 62 tomorrow. My dipstick measures exactly "full" when I change the oil using the prescribed amount of oil, so I think the combination of my dipstick and tube are just right.
Old 12-29-2010, 10:56 AM
amtronic1
amtronic1's Avatar
And the punch line is:
"Wow! The water's cold!"
"And it's deep, too!"
Old 12-29-2010, 11:31 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
This is what I had to do with my new rebuild motor. And yes it was off from the new dipstick and tube. I then marked it on the new one with a bigger cut into the dipstick..Then made one more below than the same distance as was mark one qt low.
Old 12-30-2010, 12:03 AM
62Jeff
62Jeff's Avatar
Dipstick Tube - The exposed portion of my dipstick tube is 8 1/8" long from the block to the opening for the dipstick.
To summarize:
Dipstick - Overall length 21 1/2" from tube top to tip. "FULL" line is 19 7/16" from the tube top.
Dipstick Tube - Overall length is 8 1/8" as measured outside of the block.
My dipstick tube is a little loose and cna be removed from my block, so if you need photos/measurements of the dipstick and tube out of the engine, let me know that won't be hard.
Old 01-02-2011, 12:59 AM
Uncle Ralphy
Thanks for the information guys. Mine measures very close to 62Jeff's.
To Dipstick Length??
Quick Reply: Dipstick Length??
