1963 327 250hp hard to crank & drains battery
Old 01-01-2011, 08:27 PM
black1961
black1961's Avatar
Default 1963 327 250hp hard to crank & drains battery
Posting for my brother, who has a nice early 63 convertible. He has rebuilt the chassis and done a lot of work on the car but is frustrated with it. With a fully charged battery, the engine is hard to crank and doesn't spin as quickly/or freely as it should. The engine starts fine, but the slow/hard crank drains the battery. The battery, starter and cables are new. Repeated starts drains the battery completely and he is looking for a jumpstart or battery charger. When the engine is running, the gauges indicate that the battery is charging. The engine runs well with good power. The car still has the original engine and was rebuilt in 1978. It should spin like a top when cranked, but instead we are scratching our heads. Any ideas would be appreciated. Thanks in advance, black1961
Old 01-01-2011, 08:30 PM
5thvet
5thvet's Avatar
How old is the battery? Even when you fully charged an old battery you can drain it pretty quickly. Might just need a new battery.
Old 01-01-2011, 08:34 PM
Hitch
Hitch's Avatar
That or to much initial timing...
Old 01-01-2011, 08:58 PM
vettsplit 63
vettsplit 63's Avatar
Location: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
Another thing to look at is the starter-- bad alignment can cause the starter to drag.
Old 01-02-2011, 02:25 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
The connections at both ends of both cables need to be clean and shiny; resistance can climb in a hurry if they're not. If it's tuned properly, it should fire right up without extended cranking. If the bypass wire from the "R" terminal on the starter to the coil (+) terminal isn't in place, it'll crank all day and never start.
Old 01-02-2011, 03:21 PM
MiguelsC2
MiguelsC2's Avatar
St. Jude Donor '10-'12-'13
A properly charged battery should be able to turn that starter plenty long.
Assuming your connections are correct and tight. I would bet it's a charging issue. Make sure the voltage regulator is grounded with its own wire from the reg base to the radiator support. Then have the alternator tested. Buy a low priced multi meter at the auto supply. It can tell you all you need to know. You should be getting 13.8 + volts from the alt,horn relay and at the battery when charging.
If the engine does not turn freely and takes a long time to start? Then you might need to look at timing issues.
Old 01-02-2011, 03:43 PM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
I'd have a look inside the starter motor. It may just need a cleaning of the armature, new brushes and lube on the end bushings. It could have other problems too.
Old 01-02-2011, 04:32 PM
gofastvette
gofastvette's Avatar
before you do that, re-read John`s comment above
Old 01-02-2011, 04:46 PM
Kerrmudgeon
Kerrmudgeon's Avatar
Received 4,583 Likes on 2,157 Posts
C1 of Year Finalist (appearance mods) 2019
If the battery is tested good on a load test, then I would agree with the guys and suspect either the connections or the starter is drawing way too much juice. Has the timing been messed with? Check it statically before you retry it.
Old 01-02-2011, 04:50 PM
TheSaint
TheSaint's Avatar
If it turns out to be the battery i would replace it with one that gives a lot of starting amperes
To 1963 327 250hp hard to crank & drains battery
Quick Reply: 1963 327 250hp hard to crank & drains battery
