L79 Fuel Line fitting
My first dumb question is: what happened to the old one?
I would obviously try to match it up with the old one, but if it got lost, stolen, eaten by the dog, I'd start with matching up your fuel pump threads along with the OD of your line.
Don't be surprised if your fuel pump is not "clocked" correctly, when you try to hook it up...
Harry
Engine build project. No "old" one exists.
Received 1,857 Likes
1/4" NPT male x 5/16" female inverted flare.
Got the right fitting. Ones brass and the other is chrome to match the fuel line. I'd think the brass would be better. What do you recommend? Also, how far should I screw the fitting into the fuel pump? Thanks
The chromed brass fitting will work fine; use a light film of TFE pipe dope on the threads and tighten to 80-100 INCH-lbs. (it's a tapered pipe thread).
