Pre lube a 327
I am using a drill. I have let it run for 1-2 min at a time and I have nothing.Good pressure and the drill even starts to drag as if it deadheading because of the pressure. I have spun the engine over but have got nothing.
Make sure there's a distributor body (or equivalent) in place to force the oil into the oil galleries. If the lower portion (which looks like a spool) is missing, oil won't be forced into the lifter galleries - it will just escape back to the pan.
To reiterate my first question are you using a prelube tool that the drill spins or what are you using to couple to the oil pump shaft. As Larry stated above, you need to use either a special tool or old distributor and make sure it is seated all the way down on the block to plug the oil galleys.
Received 1,857 Likes
The tool below the distributor is what you need - note the spool at the bottom; if you don't have the spool, you won't get any oil pressure in the lifter galleries.
You aren't by chance running the drill backwards are you?
Edit: Never mind, you said you have good pressure.
Good Video, they took the time to elaborate on the mistakes. Plan for ventilation, cooling fans should be set up to go in advance. Once the engine is warm double check all the radiator and heater hose clamps. They will need an extra tightening once the hoses reach temp. Watch the temp and oil pressure very close while breaking in the cam. If necessary a garden hose misting the radiator can drop temp quickly but the fan will pull this all over your clean engine and car. Easier to clean up this mess than pull a new engine back out due to overheat. Be careful and good luck. Hope it runs great!!
When the engine-start video ends, you'll find the body drop session for that car in the other titles across the bottom of the screen. It Top-Flighted first time out.
Hooked a starter it and spun it while pre-lubing. Finally got some oil up top, but found another issue. Check out the video. Not sure what happened to it or how long it was that way.
http://www.youtube.com/watch?v=Hx3qdzEpnHM
Crank snout looks OK, as the pulleys and balancer hub are running true, but the inertia ring isn't; time to replace the balancer or have it rebuilt.
Balancer wobble
RON
I don't think it was dropped---Take a close look at the video--The outer ring on the balancer is wobbling, but the pulleys are straight as an arrow. The pulleys bolt to the balancer hub which is evidently ok and true. It looks like the balancer outer ring is cocked on the hub.
RON
Crank is ok and the pulleys run true - time for another balancer!
I was thinking that if it were dropped on the nose, before the pulleys were installed, it would damage the balancer as shown, but also possibly push the crank into the block to damage thrust surfaces. When I reference crank damage, it is that to which I was referring, not a bent crank snout.
