67 differntial mounting bracket
Received 6,944 Likes
2015 C2 of Year Finalist
should the front bracket have the reinforcements or not.
Received 2,127 Likes
Kieth, Are you referring to the fromt mount at the pinion? I have not ever seen one that the edges aren't rolled when formed in the press. Dennis
Received 1,857 Likes
The long welded-on reinforcements on both sides didn't start until 1969; 1966-68 had a single washer welded on each side for the forward bolt. Photo below shows the '69-up bracket at the top, and the '66-'67 bracket at the bottom.
As I have said before, I learn something new from every day, and JohnZ. Dennis
So did dad and I. We learned his coupe has a later style bracket and a rear from a 1977.
