1961 VIN tag, when placed on column during assembly?
Old 02-06-2011, 05:03 PM
AZDoug
AZDoug's Avatar
Received 1,478 Likes on 905 Posts
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Default 1961 VIN tag, when placed on column during assembly?
My car came a with a dealer replacement VIN tag (correct VIN for the frame) screwed on the door jam when I bought it in 1974.
I was cleaning up the steering column for repaint and noticed red paint on the column where a VIN tag was originally. This would have been under the tag.
Was this red paint over spray from one of its previous repaints after the tag was removed from the column, or red from the factory?
In other words, was the tag welded to the column after final body paint, and would factory red have migrated that far into the engine compartment?
Doug
Old 02-07-2011, 02:25 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
Doug
The '61-'62 gear/column tube came from Saginaw Steering Gear with the tube painted black primer, and the upper portion of the tube and turn signal housing was painted interior color before the gear/column was installed in the body, long after the body Paint Shop. The VIN plate was resistance spot-welded to the tube after the tube was painted, before it went into the body. On a '61-'62, there shouldn't be any interior trim color paint on the tube forward of the firewall; only the portion inside the cabin was painted, and the length of tube visible in the engine compartment should be black.
This was a really dumb design (spot-welding a stainless steel tag to a painted plain steel tube), which is why many of them fell off.
Old 02-07-2011, 03:22 PM
AZDoug
AZDoug's Avatar
Thanks.
Finding red paint on the tube, where the tag was, would indicate the tag fell off early in life, and an early repaint accounted for the red, since no work was done on the car from 1969 when it was damaged until i got it in 1974, and apparently two repaints were done in the 1960's, the first was bare fiberglas strip and gel coat (based on the gelcoat I found in 1974) and red spray, and a second red spray over the first one sometime later.
Working on an old car is like an archaeological dig, if you remove the layers slowly, you get a feel of what its history was.
Doug
Old 09-11-2012, 11:01 AM
Archer156
4th Gear
Archer156's Avatar
Where is the body tag on a 61 ? Just bought one and trying to find original paint and interior colors
Old 09-11-2012, 11:26 AM
mike coletta
mike coletta's Avatar
Received 1,067 Likes on 513 Posts
There isn't one. The only tag on a 61 is the VIN tag being discussed.
Mike Coletta
Old 09-11-2012, 11:29 AM
wmf62
wmf62's Avatar
St. Jude Donor '07
Thanks.
Doug
yep, i found 3 different colors on mine... hugger orange when i bought it, blue under that, and the original Sateen Silver.
BUT corvettes are supposed to be red, so that's what i painted it...
Bill
Old 09-11-2012, 01:58 PM
Archer156
4th Gear
Archer156's Avatar
Thanks.
Old 09-11-2012, 03:59 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
Doug
this is a pic of my original column
Bill
To 1961 VIN tag, when placed on column during assembly?
Quick Reply: 1961 VIN tag, when placed on column during assembly?
