63 SWC Question re. felt & vent window rivets
I ordered felt replacement for the window tracks and replacement rubber for the vent windows. In both cases I had remove small (1/4" head) rivets. The new rivets (similar but not the same) came with the replacement pieces. Is there a special tool to flange the back end of the tool during re-installation? Where do you get it?
Also, since the new window track felt is slightly narrower than OEM it is not perfectly snug in there. Should I lightly expoxy it into the channel?
Thanks in advance.
Thanks in advance.
Received 1,762 Likes
Thanks in advance.
Thanks in advance.
1963, c3, corvette, felt, installation, remove, repair1958, replacement, rivets, rivits, vent, window
