Heater Blower Motor Troubleshooting
I am in the process of reassembling my 65.
The heater blower motor worked before I took it all apart,as far as I remember, but doesn't now.
It is a non-a/c car with all new wiring harnesses.
I tested the output at the wires to the blower...it reads about 10.5V when blower switch is on ( battery is not fully charged)
If I am getting power to the blower and it is not working, does that eliminate the heater resistor as the problem?
Before I go through the trouble of removing the blower I want to be sure it is the problem
Received 1,858 Likes
Yes, the ground wire is hooked up. I have it hooked into the spade that one of the screws that holds the motor in place goes through.
Didn't go under to look at starter but when I hooked up the starter it seemed pretty straightforward and there were no extra wires
Wiper motor is working.
The resister is pretty easy to get to under the dash from memory. (I could be remembering my Plymouth however, the Corvette one may be on top the heater box). You may need to pull it out or jump the terminals to bypass it momentarily.
Dan
Dragin88 (09-10-2022)
Have you ohmed out the ground wire to make sure it is really grounded? If you have 1.5 volts on one wire and ground on the other, the blower motor should at least be trying to turn.
Received 6,946 Likes
2015 C2 of Year Finalist
a simple thing is the fuse blown or the correct amp fuse
Since you are almost on top of the battery, take a ground from the battery and ground it to the ground on the blower. Next take a wire directly from the positive of the battery to the power side of the blower motor. The motor should come to life. If it does not, replace the blower motor. Jerry
You got it.....but there is more to it...I'm not a total idiot
Before your post, i took out the blower motor. That was fun.
Brought it inside and hooked it up to 12V and it ran.
Re-installed it....didn't run.
Read your post....keep in mind that all the wiring is brand new, and the fuses are all brand new.....but even so I went to check. Pulled the fuse and it wasn't blown and was the correct 10 amp fuse.
Just for the heck of it replaced it with another new 10 amp fuse....and it works!
Tested the original fuse with meter...no continuity.
The problem was a defective fuse.
Waste of an afternoon....but at least it's solved.
Thanks to all for your help
1960 (08-29-2021)
your welcome. don't feel bad I think we all done that working on our own cars. its always the simple stupid things that go bad. but the the good thing is you found it and fixed it
1960 (08-29-2021)
